I’ve tried to setup mit Doorbird like described here: https://github.com/openhab/openhab/wiki/DoorBird
The problem now is that the registration url’s are not called by openhab. I found out that the percent chars in the url are causing this problem. As soon as I remove all percent signs from the url the url is called. But for this to work I have to pass an url encoded parameter to the device which. Here is an example:
Switch SW_DoorBird_Test { http=">[ON:GET:http://my.doorbird?url=http://172.17.2.21:8080/CMD%3FSW_Test%3DON]" }
How can I get OpenHAB to call this url?
