I have just downloaded and tried to update to the latest “offline” snapshot #373 and there appears to be a problem with the zwave binding. I had the same issue yesterday with #372, but thought it might be a download issue. I see there are issues with the upstream build of the openHAB2-Addons.
As the failing tests are not about zwave, I do not think that they are related to your problem. So it probably makes sense to specify your problems with some more details.
I tried to install today’s offline snapshot #374 and found the same problems as yesterday.
My environment is Windows 7 64bit
the first thing I see is that the icons are not showing in either the Classic or Basic UI.
secondly there are multiple error messages when I run log:tail that are not normal in my experience. Following is a link to the log file following today’s update:
I have now reverted to my backup, which is based on a snapshot from around 20/6/16 (I am now keeping notes of the build number for future updates). Everything is working normally again.
My immediate issue is I want to update to the latest version of the zwave binding, but as I use the offline snapshot, it is my understanding that I need to download a full new snapshot.
I have also kept a full copy of snapshot #374 installed so please let me if you need me to check anything else.
i can confirm that I have the same behaviour with icons not showing up in windows 10 64bit in classic and basic UI in snapshot #373. Icons are still showing in the iphone app.
I analyzed the missing icons on Windows and can confirm it is a bug. It will be fixed with https://github.com/eclipse/smarthome/pull/1759, which should become available in the openHAB distro by tomorrow.
@Kai, I installed snapshot #380 today but still no icons in either the Classic or Basic UI.
Any suggestions? Maybe there is a problem with my preparation process before updating? Following is the batch file that I run in Windows, prior to extracting the new snapshot into c:\openhab. I then restore addons.cfg and runtime.cfg from my backup, before restarting.
Note: this update process has worked fine for the last 2 months. I have been typically updating once a week at least.
@echo Please confirm that you have shut down openHAB.
@echo ===============================================
@echo This routine will backup openHAB and then prepare for updating to the latest snapshot.
@echo ======================================================================================
pause
cd\oh_backup
del *.* /s /q
cd\
xcopy c:\openhab\*.* c:\oh_backup /v /q /s /e /h
@echo backup completed - preparation next....
pause
rd c:\openhab\runtime /s /q
del /s /f /q c:\openhab\userdata\cache\*.*
for /f %%f in ('dir /ad /b c:\openhab\userdata\cache\') do rd /s /q c:\openhab\userdata\cache\%%f
del /s /f /q c:\openhab\userdata\tmp\*.*
for /f %%f in ('dir /ad /b c:\openhab\userdata\tmp\') do rd /s /q c:\openhab\userdata\tmp\%%f
@echo Task completed
pause
What else do you need from me to help track down the problem?
