Can’t really see what you are hoping to happen, much depends in Item names and Group memberships that we cannot see.
Break your code open a bit, step by step, and check values arewhat you expected. What is item.label? What is TempText?
the result is
Termostat_KA_Temp_Ist_Label : Termostat_KA_Temp_Ist_State |Katzenzimmer Soll Temperatur: 18.00 °C
Termostat_SZ_Temp_Ist_Label : Termostat_SZ_Temp_Ist_State |Schlafzimmer Soll Temperatur: 12.00 °C
Termostat_WZ_Temp_Ist_Label : Termostat_WZ_Temp_Ist_State |Wohnzimmer Soll Temperatur: 15.00 °C
Termostat_KU_Temp_Ist_Label : Termostat_KU_Temp_Ist_State |Küche Soll Temperatur: 18.00 °C
Termostat_BU_Temp_Ist_Label : Termostat_BU_Temp_Ist_State |Büro Soll Temperatur: 10.00 °C
Termostat_KZ_Temp_Ist_Label : Termostat_KZ_Temp_Ist_State |Kinderzimmer Soll Temperatur: 18.00 °C
Termostat_BR_Temp_Ist_Label : Termostat_BR_Temp_Ist_State |Bad Soll Temperatur: 17.00 °C
I expect:
Katzenzimmer Ist Temperatur : 18.00 °C |Katzenzimmer Soll Temperatur: 18.00 °C
Schlafzimmer Ist Temperatur: 12.00 °C |Schlafzimmer Soll Temperatur: 12.00 °C
Wohnzimmer Ist Temperatur: 15.00 °C |Wohnzimmer Soll Temperatur: 15.00 °C
Küche Ist Temperatur: 18.00 °C |Küche Soll Temperatur: 18.00 °C
Büro Ist Temperatur: 10.00 °C |Büro Soll Temperatur: 10.00 °C
Kinderzimmer Ist Temperatur: 18.00 °C |Kinderzimmer Soll Temperatur: 18.00 °C
Bad Ist Temperatur: 17.00 °C |Bad Soll Temperatur: 17.00 °C
I try to describe what i wanna do
rule "Report Temp by Telegram"
Item LastMessageText received update "Überblick"
// prepare a empty var
var String TempText = ""
// Prepare the Telegram Bot
val telegramAction = getActions("telegram","telegram:telegramBot:86d92b46")
// get the "To" temperatures
// allTermostatSoll
Group allTermostatSoll "Alle Termostate Soll zustand" [ "Thermostat", "Celsius" ]
Group allTermostatIst "Alle Termostate ist Zustand" [ "Thermostat", "Celsius" ]
Group gTermostat_WZ "Wohnzimmer Heizung" <sofa> [ "Thermostat", "Celsius" ]
String Termostat_WZ_Modus "Wohnzimmer Heating/Cooling Mode" (gTermostat_WZ) [ "HeatingCoolingMode" ] {channel="homematic:HM-CC-RT-DN:3014F711A0001F58A9A70C4:KEQ072361:4#CONTROL_MODE"}
Number:Temperature Termostat_WZ_Temp_Soll "Wohnzimmer Soll Temperatur" (gTermostat_WZ,allTermostatSoll) [ "TargetTemperature" ] {channel="homematic:HM-CC-RT-DN:3014F711A0001F58A9A70C4:KEQ072361:4#SET_TEMPERATURE"}
Number:Temperature Termostat_WZ_Temp_Ist "Wohnzimmer Ist Temperatur" (gTermostat_WZ,allTermostatIst) [ "CurrentTemperature" ] {channel="homematic:HM-CC-RT-DN:3014F711A0001F58A9A70C4:KEQ072361:4#ACTUAL_TEMPERATURE"}
Group gTermostat_KU "Küche Heizung" <kitchen> [ "Thermostat", "Celsius" ]
String Termostat_KU_Modus "Küche Heating/Cooling Mode" (gTermostat_KU) [ "HeatingCoolingMode" ] {channel="homematic:HM-CC-RT-DN:3014F711A0001F58A9A70C4:KEQ072823:4#CONTROL_MODE"}
Number:Temperature Termostat_KU_Temp_Soll "Küche Soll Temperatur" (gTermostat_KU,allTermostatSoll) [ "TargetTemperature" ] {channel="homematic:HM-CC-RT-DN:3014F711A0001F58A9A70C4:KEQ072823:4#SET_TEMPERATURE"}
Number:Temperature Termostat_KU_Temp_Ist "Küche Ist Temperatur" (gTermostat_KU,allTermostatIst) [ "CurrentTemperature" ] {channel="homematic:HM-CC-RT-DN:3014F711A0001F58A9A70C4:KEQ072823:4#ACTUAL_TEMPERATURE"}
// add a line with placeholder to TempText "Termostat_KA_Temp_Ist_Label : Termostat_KA_Temp_Ist_State |Katzenzimmer Soll Temperatur: 18.00 °C\n"
allTermostatSoll.members.forEach[item | TempText = TempText + item.name.replace("Soll","Ist") +"_Label : "+ item.name.replace("Soll","Ist") +"_State |"+ item.label + ": "+ item.state.toString +"\n"]
// Run a 2nd foreach to replace the placeholder "Termostat_KA_Temp_Ist_Label" with the value of "item.label"
// item.name+"_Label" should be "Termostat_KA_Temp_Ist_Label"
allTermostatIst.members.forEach[item | TempText.replace(item.name+"_Label",item.label) logInfo("TempTest", item.name+"_Label") ]
allTermostatIst.members.forEach[item | TempText.replace(item.name+"_State",item.state.toString)]
// Send the TempText as message
telegramAction.sendTelegram(TempText)
logInfo("TempTest",TempText)
I repeat, step by step. One big string at the end of the rule does not help you find out which step did not perform as you expected.
You have put some intermediate logging in, but kept the results secret.
Thx for it, there was a second fault but i found. the Los is now a bit weird.
2020-09-13 21:21:35.148 [INFO ] [.eclipse.smarthome.model.script.test] - replacing Termostat_WZ_Temp_Ist_Label with Wohnzimmer Ist Temperatur
2020-09-13 21:21:35.158 [INFO ] [.eclipse.smarthome.model.script.test] - Step with Item Termostat_KU_Temp_Ist
2020-09-13 21:21:35.164 [INFO ] [.eclipse.smarthome.model.script.test] - Step starts with Termostat_KA_Temp_Ist_Label : Termostat_KA_Temp_Ist_State |Katzenzimmer Soll Temperatur: 18.00 °C
Termostat_KU_Temp_Ist_Label : Termostat_KU_Temp_Ist_State |Küche Soll Temperatur: 12.00 °C
2020-09-13 21:21:35.175 [INFO ] [.eclipse.smarthome.model.script.test] - replacing Termostat_KU_Temp_Ist_Label with Küche Ist Temperatur
2020-09-13 21:21:35.184 [INFO ] [.eclipse.smarthome.model.script.test] - Step with Item Termostat_SZ_Temp_Ist
2020-09-13 21:21:35.191 [INFO ] [.eclipse.smarthome.model.script.test] - Step starts with Termostat_KA_Temp_Ist_Label : Termostat_KA_Temp_Ist_State |Katzenzimmer Soll Temperatur: 18.00 °C
2020-09-13 21:21:35.201 [INFO ] [.eclipse.smarthome.model.script.test] - replacing Termostat_SZ_Temp_Ist_Label with Schlafzimmer Ist Temperatur
2020-09-13 21:21:35.211 [INFO ] [.eclipse.smarthome.model.script.test] - Step with Item Termostat_KZ_Temp_Ist
2020-09-13 21:21:35.217 [INFO ] [.eclipse.smarthome.model.script.test] - Step starts with Termostat_KA_Temp_Ist_Label : Termostat_KA_Temp_Ist_State |Katzenzimmer Soll Temperatur: 18.00 °C
2020-09-13 21:21:35.227 [INFO ] [.eclipse.smarthome.model.script.test] - replacing Termostat_KZ_Temp_Ist_Label with Kinderzimmer Ist Temperatur
2020-09-13 21:21:35.236 [INFO ] [.eclipse.smarthome.model.script.test] - Step with Item Termostat_BR_Temp_Ist
2020-09-13 21:21:35.242 [INFO ] [.eclipse.smarthome.model.script.test] - Step starts with Termostat_KA_Temp_Ist_Label : Termostat_KA_Temp_Ist_State |Katzenzimmer Soll Temperatur: 18.00 °C
2020-09-13 21:21:35.250 [INFO ] [.eclipse.smarthome.model.script.test] - replacing Termostat_BR_Temp_Ist_Label with Bad Ist Temperatur
2020-09-13 21:21:35.258 [INFO ] [.eclipse.smarthome.model.script.test] - Step with Item Termostat_KA_Temp_Ist
2020-09-13 21:21:35.263 [INFO ] [.eclipse.smarthome.model.script.test] - Step starts with Termostat_KA_Temp_Ist_Label : Termostat_KA_Temp_Ist_State |Katzenzimmer Soll Temperatur: 18.00 °C
2020-09-13 21:21:35.272 [INFO ] [.eclipse.smarthome.model.script.test] - replacing Termostat_KA_Temp_Ist_Label with Katzenzimmer Ist Temperatur
2020-09-13 21:21:35.287 [INFO ] [.eclipse.smarthome.model.script.test] - Step with Item Termostat_BU_Temp_Ist
2020-09-13 21:21:35.292 [INFO ] [.eclipse.smarthome.model.script.test] - Step starts with Termostat_KA_Temp_Ist_Label : Termostat_KA_Temp_Ist_State |Katzenzimmer Soll Temperatur: 18.00 °C
2020-09-13 21:21:35.301 [INFO ] [.eclipse.smarthome.model.script.test] - replacing Termostat_BU_Temp_Ist_Label with Büro Ist Temperatur
2020-09-13 21:21:35.682 [INFO ] [ipse.smarthome.model.script.TempTest] - Termostat_KA_Temp_Ist_Label : Termostat_KA_Temp_Ist_State |Katzenzimmer Soll Temperatur: 18.00 °C
Okay, so it clearly shows the replace does not work. Or rather, the string that the replace operates on does not survive outside of the lambda.
This is one of those things about passing variables out of lambdas, basically you can’t. So each iteration of the forEach gets the unaltered ‘outside’ version of the string.
The basic problem is tackled here - use of StringBuilder allows appending within a lambda.
however I’m not sure what you should do to edit a pre-existing string within a lambda.
Are you filtering the logs here? I’m surprised it is not complaining about ‘non-final variables’
You have a group of Items Termostat_xxx_Ist, each of which has a counterpart Termostat_xxx_Soll
You want to produce some text for this set like
" xxx ist-label : 12.00 °C | xxx soll-label : 18.00 °C
yyy ist-label : 15.00 °C | yyy soll-label : 16.00 °C"
// make a stringy object val that we can still append to
val StringBuilder myMessage = new StringBuilder
// iterate through "Ist" Items
allTermostatIst.members.forEach[ist |
// add label text
myMessage.append(ist.label + " : ")
// add state
myMessage.append(ist.state.toString + " | ")
// work out partner Item name
val sollName = ist.name.replace("_Ist", "_Soll")
// get partner Item from its group
val soll = allTermostatSoll.members.findFirst[ a | a.name == sollName]
if (soll === null) {
// surprise
myMessage.append("Missing Soll Item " + sollname)
} else {
// now do soll label and value
myMessage.append(soll.label + " : ")
myMessage.append(soll.state.toString + "/n")
// all done
telegramAction.sendTelegram(myMessage)
