Hi
I’ve tried to install MCP23017 binding (from https://openhab.ci.cloudbees.com/job/openHAB1-Addons/lastSuccessfulBuild/artifact/bundles/binding/org.openhab.binding.mcp23017/target/).
but when I copied this to adds directory thera are problem with starting Openhab.
In the openhablog there are following information. “Started dashboard…” is displayed every 10seconds (in a loop):
2017-07-02 12:48:31.703 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at http://192.168.1.10:8080
2017-07-02 12:48:31.720 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at https://192.168.1.10:8443
2017-07-02 12:48:46.125 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'test.items'
2017-07-02 12:48:54.990 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'test.rules'
2017-07-02 12:49:44.305 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at http://192.168.1.10:8080
2017-07-02 12:49:44.322 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at https://192.168.1.10:8443
When I remove MCP file from addson directory Openhab start without any problems.
Michal
