Problem with my Rules File
I have a problem with my rules file, I thought I would strip it back to the basics, and add the rules one by one to find the problem, however the problem seems to be on the first rule, which actually used to work
This is the error
2019-02-02 08:46:07.289 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'home.rules'
2019-02-02 08:46:07.304 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'home.rules' is either empty or cannot be parsed correctly!
2019-02-02 08:46:07.605 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'home.rules'
This is the rules file
var Timer md1Timer = null
val int timeoutMinutes = 10
rule "Downstairs Toilet"
    Item DownstairsToilet changed from OFF to ON
           md1Timer = createTimer(now.plusMinutes(timeoutMinutes ), [|
           DownstairsToilet.sendCommand(OFF)
           md1Timer = null
Any ideas will be appreciated.
Seve
Don’t think there is anything wrong with your rule, unless it does not do what you want.
A quick search of the forum would have shown you plenty of entries with the explanation for your warning:
