i configured the binding with OH2 on a Raspi 3B with Fritzbox 7390. The resolved is shown somewhere in the LOG, but at the end the Item does not contain it. Any idea?
Items:
Call fboxIncomingCall "Incoming call: [%1$s to %2$s]" {fritzboxtr064="callmonitor_ringing" }
Call fboxIncomingCallResolved "Incoming call: [%1$s to %2$s]" {fritzboxtr064="callmonitor_ringing:resolveName" }
Switch fboxRinging "Phone ringing [%s]" {fritzboxtr064="callmonitor_ringing" }
Rule:
rule "Telefonanruf eingehend"
Item fboxRinging changed to ON
logInfo("rules", "Telefonanruf eingehend")
val incCall = fboxIncomingCall.state as StringListType
val callerNumber = incCall.getValue(1)
val incCallResolved = fboxIncomingCallResolved.state as StringListType
val callerName = incCallResolved.getValue(1)
logInfo("rules", "Nummer: {}", callerNumber)
logInfo("rules", "Name: {}", callerName)
logInfo("rules", "Resolved: {}", incCallResolved)
Logs:
2018-08-13 11:55:08.878 [INFO ] [tzboxtr064.internal.PhonebookManager] - Trying to resolve number 0175xxxx170 to name comparing 7 characters
2018-08-13 11:55:08.887 [INFO ] [tzboxtr064.internal.PhonebookManager] - found name match Christian yyyyyyyy in phonebook by comparing 071xxxx 571 94+ with 071xxxx
2018-08-13 11:55:08.913 [vent.ItemStateChangedEvent] - fboxIncomingCall changed from to 55xxxx,0175xxxx170
2018-08-13 11:55:08.921 [vent.ItemStateChangedEvent] - fboxIncomingCallResolved changed from to 55xxxx,Name not found for 0175xxxx170
2018-08-13 11:55:08.932 [vent.ItemStateChangedEvent] - fboxRinging changed from OFF to ON
2018-08-13 11:55:09.163 [INFO ] [eclipse.smarthome.model.script.rules] - Telefonanruf eingehend
2018-08-13 11:55:09.173 [INFO ] [eclipse.smarthome.model.script.rules] - Nummer: 0175xxxx170
2018-08-13 11:55:09.176 [INFO ] [eclipse.smarthome.model.script.rules] - Name: Name not found for 0175xxxx170
2018-08-13 11:55:09.180 [INFO ] [eclipse.smarthome.model.script.rules] - Resolved: 55xxxx,Name not found for 0175xxxx170
