I’m running on 1.8.3 installed from apt-get, I’ve noticed that I’ve been getting errors with the nest binding. I even went as far as pulling all my nest items from items and sitemap and I’m still seeing this error. I even downloaded the addons zip file and replaced the JAR and still get the same warning.
2016-09-17 20:04:06.473 [WARN ] [.o.b.nest.internal.NestBinding] - Exception reading from Nest.
org.openhab.binding.nest.internal.NestException: Could not get data model.
at org.openhab.binding.nest.internal.messages.AbstractRequest.newException(AbstractRequest.java:91) ~[na:na]
at org.openhab.binding.nest.internal.messages.DataModelRequest.execute(DataModelRequest.java:66) ~[na:na]
at org.openhab.binding.nest.internal.NestBinding.readNest(NestBinding.java:189) ~[na:na]
at org.openhab.binding.nest.internal.NestBinding.execute(NestBinding.java:168) ~[na:na]
at org.openhab.core.binding.AbstractActiveBinding$BindingActiveService.execute(AbstractActiveBinding.java:156) [org.openhab.core_1.8.3.jar:na]
at org.openhab.core.service.AbstractActiveService$RefreshThread.run(AbstractActiveService.java:173) [org.openhab.core_1.8.3.jar:na]
Caused by: java.lang.NullPointerException: null
at org.openhab.binding.nest.internal.messages.Structure.sync(Structure.java:313) ~[na:na]
at org.openhab.binding.nest.internal.messages.DataModel.sync(DataModel.java:478) ~[na:na]
at org.openhab.binding.nest.internal.messages.DataModelRequest.execute(DataModelRequest.java:62) ~[na:na]
... 4 common frames omitted
