I’m using the latest pull release of the netamo binding and, after a couple of hours, i receive the following message:
2018-10-22 19:02:23.953 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception
retrofit.RetrofitError: 404 Not Found
at retrofit.RetrofitError.httpError(RetrofitError.java:40) ~[?:?]
at retrofit.RestAdapter$RestHandler.invokeRequest(RestAdapter.java:388) ~[?:?]
at retrofit.RestAdapter$RestHandler.invoke(RestAdapter.java:240) ~[?:?]
at com.sun.proxy.$Proxy193.getlasteventof(Unknown Source) ~[?:?]
at org.openhab.binding.netatmo.internal.welcome.NAWelcomePersonHandler.updateChannels(NAWelcomePersonHandler.java:50) ~[?:?]
at org.openhab.binding.netatmo.internal.handler.NetatmoDeviceHandler.lambda$7(NetatmoDeviceHandler.java:202) ~[?:?]
at java.util.Optional.ifPresent(Optional.java:159) ~[?:?]
at org.openhab.binding.netatmo.internal.handler.NetatmoDeviceHandler.lambda$5(NetatmoDeviceHandler.java:200) ~[?:?]
at java.util.concurrent.ConcurrentHashMap.forEach(ConcurrentHashMap.java:1597) ~[?:?]
at org.openhab.binding.netatmo.internal.handler.NetatmoDeviceHandler.updateChildModules(NetatmoDeviceHandler.java:198) ~[?:?]
at org.openhab.binding.netatmo.internal.handler.NetatmoDeviceHandler.updateChannels(NetatmoDeviceHandler.java:158) ~[?:?]
at org.openhab.binding.netatmo.internal.handler.NetatmoDeviceHandler.lambda$0(NetatmoDeviceHandler.java:84) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
and the binding stops to update.
I’m using also the Netatmo thermostat with the same bindong with no problems.
Thanks a lot. for your support.
