Hi all,
Solved the problem, something wrong in the timer logic. Working rule below for those interested.
Joost
var Timer IR_timer // track that command is actually different from prev (200ms)
var String IR_prevCmd = ""
// rules for remote
// execute function based on pressed key on harmony remote
rule "Handle IR Keys via TCP"
Item IR_command received update
var kodiPar = ""
//logInfo("IR_command:", IR_command.state.toString())
// strip and get key
var String[] buffer = IR_command.state.toString.split(" ")
// check if we can extract something
if (buffer.size()>=2) {
var command = buffer.get(2)
// check if new command, timer handles repeats
if (IR_prevCmd != command) {
IR_prevCmd = command
logInfo("IR stripped command", "received: " + command +"\n");
// set kodi param based on key
switch command {
// top section
case "KEY_PREVIOUSSONG": { kodiPar="stepback" } // << or bigstepback or skipprevious
case "KEY_REWIND": { kodiPar="rewind" } // <
case "KEY_NEXTSONG": { kodiPar="stepforward" } // >> can also be bigstepfoward or skipnext
case "KEY_FASTFORWARD": { kodiPar="fastforward" } // >
case "KEY_PAUSE": { kodiPar="playpause" }
case "KEY_PLAY": { kodiPar="playpause" }
case "KEY_RECORD": { kodiPar="" }
case "KEY_STOPCD": { kodiPar="stop" }
// touch section
case "KEY_POWER": { kodiPar="" } // prevent shutdown!
// want to assign some custom keys here, e.g. spotify, games, based on keyb commands?
// e.g. pres touch-key "SPOTIFY" send KEY_ALT_Q -> calls Kodi run addon "Spotify" or something
// bottom section
case "KEY_ESC": { kodiPar="close" } // not sure if this is the right one
case "KEY_MENU": { kodiPar="contextmenu" } // UNASSIGNED IN REMOTE
case "KEY_UP": { kodiPar="up" }
case "KEY_DOWN": { kodiPar="down" }
case "KEY_LEFT": { kodiPar="left" }
case "KEY_RIGHT": { kodiPar="right" }
// special case: if playing, show OSD else enter
case "KEY_ENTER": {
var player = xbmcPlayerState.state.toString()
switch player {
case "Play": { kodiPar="enter" }
// default is select
default: { kodiPar="select" } // must be select
case "KEY_VOLUMEUP": { kodiPar="volumeup" }
case "KEY_VOLUMEDOWN": { kodiPar="volumedown" }
case "KEY_CHANNELUP": { kodiPar="pageup" }
case "KEY_CHANNELDOWN": { kodiPar="pagedown" }
case "KEY_MUTE": { kodiPar="mute" }
case "KEY_BACK": { kodiPar="back" } //
case "KEY_DVR": { kodiPar="" }
case "KEY_PROGRAM": { kodiPar="" } // guide
case "KEY_PROPS": { kodiPar="info" } // info
case "KEY_RED": { kodiPar="" }
case "KEY_GREEN": { kodiPar="" }
case "KEY_YELLOW": { kodiPar="" }
case "KEY_BLUE": { kodiPar="" }
// if we have something, send it
if (kodiPar != "") {
logInfo("Sending to Kodi:", kodiPar)
sendCommand(xbmcInputAction, kodiPar)
// set timer to rest the cmd
IR_timer = createTimer(now.plusMillis(100)) [|
// reset
IR_prevCmd = "";
logInfo("IR","prevCmd reset")
} else {
// nothing
logInfo("IR","ignoring, repeat")
