Hi I am used to work with two persistence services mapDB for restoring all valuesafter a restart and influxDB for longer time series. Being on the latest openhab3.01 release using openHABian on a Raspberry.
Now I have reached a point where some persistet items don’t receive any updates on influxDB anymore and new added ones also don’t get any values written in the db.
I’ve put influxdb to trace and thats what I can see as difference between the two.
An item that is correctly persisted looks like this
[openhab.event.ItemStateChangedEvent ] - Item 'z45_temperature' changed from 17.6 to 18.3
[.influxdb.InfluxDBPersistenceService] - Storing item z45_temperature (Type=NumberItem, State=18.3, Label=Waschküchentür @ 21:35, Category=temperature, Groups=[innenTemperaturMix, reportEveryChange, displayUpdate]) in InfluxDB point InfluxPoint{measurementName='z45_temperature', time=2021-04-21T19:35:11.310191Z, value=18.3, tags={item=z45_temperature}}
[.influxdb.InfluxDBPersistenceService] - Storing item z45_temperature (Type=NumberItem, State=18.3, Label=Waschküchentür @ 21:35, Category=temperature, Groups=[innenTemperaturMix, reportEveryChange, displayUpdate]) in InfluxDB point InfluxPoint{measurementName='z45_temperature', time=2021-04-21T19:35:11.313754Z, value=18.3, tags={item=z45_temperature}}
[.influxdb.InfluxDBPersistenceService] - Filter: itemname: z45_temperature, ordering: DESCENDING, state: null, operator: EQ, getBeginDate: null, getEndDate: null, getPageSize: 1, getPageNumber: 0
[.influxdb.InfluxDBPersistenceService] - Query SELECT value FROM autogen.z45_temperature ORDER BY time DESC LIMIT 1;
[rnal.influx1.InfluxDB1RepositoryImpl] - series Series [name=z45_temperature, tags=null, columns=[time, value], values=[[1.619033711313E12, 18.3]]]
**[rnal.influx1.InfluxDB1RepositoryImpl] - adding historic item z45_temperature: time 2021-04-21T19:35:11.313Z value 18.3**
An item that is not persistet like that:
[openhab.event.ItemStateChangedEvent ] - Item 'z49_door2' changed from OPEN to CLOSED
[.influxdb.InfluxDBPersistenceService] - Filter: itemname: z49_door2, ordering: DESCENDING, state: null, operator: EQ, getBeginDate: null, getEndDate: null, getPageSize: 1, getPageNumber: 0
[.influxdb.InfluxDBPersistenceService] - Query SELECT value FROM autogen.z49_door2 ORDER BY time DESC LIMIT 1;
Things done so far:
Reboot
Clear cache
Removed items from .items file then readded them
Checked on the influxdb itself, select * results no entries
Any help where to look next or what to try highly appreciated
