Problem with rules in OpenHab2
Hi
I’ve just transferred to OH2 and all of my rules have error messages against them in Eclipse SmartHome Designer. If I use
sendCommand(ZWSwitch2, OFF)
in my rule with ZWSwitch created as an item:
Switch ZWSwitch2 { channel=“zwave:device:d0472063:node13:switch_binary”}
I get a red X warning of:
Multiple markers at this line
  • The method sendCommand(Object, org.eclipse.smarthome.core.library.types.OnOffType)
    is undefined
  • The method or field ZWSwitch2 is undefined
  • The field RulesRules.OFF refers to the missing type org.eclipse.smarthome.core.library.types.OnOffType
If I do
sendCommand(ZWSwitch2, “OFF”)
I get a smaller warning of
  • The method sendCommand(Object, String) is undefined
The rule does work but makes it very hard to debug.
What am I doing wrong?
Many thanks
I am not using OH2 but it might be worth trying ZWSwitch2.sendCommand(ON).
Thanks. Same error though
Don’t use 0.9.0 of the Designer. The last stable version is 0.8.0.
