It receives this message: 20: 21: 32.794 [WARN] [el.core.internal.ModelRepositoryImpl] - Configuration model ‘dom.rules’ is either empty or can not be parsed correctly!
I do not understand him, ask for help
My ruls:
//ta ruls będzie odczytywać zmienne co 1 min
rule “odczyt_danych”
Time cron “0 * * * * ?”
//var Number LEDn
var String json = sendHttpGetRequest(“http://192.168.1.177:8080/json_inputs&nocha”)
postUpdate(TempSalon, transform(“JSONPATH”, “$.tempSalon”, json))
postUpdate(TempKuchnia, transform(“JSONPATH”,"$.tempKuchnia",json))
postUpdate(TempLazDol, transform(“JSONPATH”, “$.tempLazDol”, json))
postUpdate(Tempsyp, transform(“JSONPATH”, “$.tempsyp”, json))
postUpdate(TempKuba, transform(“JSONPATH”, “$.tempKuba”, json))
postUpdate(TempStas, transform(“JSONPATH”, “$.tempStas”, json))
postUpdate(TempMarta, transform(“JSONPATH”, “$.tempMarta”, json))
postUpdate(TempLazienka, transform(“JSONPATH”, “$.tempLazienka”, json))
postUpdate(wilgotnosc, transform(“JSONPATH”, “$.wilgotnosc”, json))
postUpdate(piec, transform(“JSONPATH”, “$.piec”, json))
postUpdate(piec2, transform(“JSONPATH”, “$.piec”, json))
postUpdate(boiler, transform(“JSONPATH”, “$.bojler”, json))
postUpdate(swiatlo, transform(“JSONPATH”, “$.swiatlo”, json))
postUpdate(TempZadana, transform(“JSONPATH”, “$.Temp_zadana”, json))
postUpdate(TempZew, transform(“JSONPATH”, “$.tempzew”, json))
postUpdate(tempStrych, transform(“JSONPATH”, “$.strych”, json))
postUpdate(wentylatorn, transform(“JSONPATH”, “$.Wentylator”, json))
if (wentylatorn.state == 0){
postUpdate(wentylator, OPEN)
if (wentylatorn.state == 1){
postUpdate(wentylator, CLOSED)
postUpdate(LEDn, transform(“JSONPATH”, “$.LED”, json))
if (LEDn.state == 0){
postUpdate(LED, OPEN)
if (LEDn.state == 1){
postUpdate(LED, CLOSED)
postUpdate(boilerP, transform(“JSONPATH”, “$.pompaB”, json))
if (boilerP.state == 0){
postUpdate(pompaB, OPEN)
if (boilerP.state == 1){
postUpdate(pompaB, CLOSED)
postUpdate(COpompa, transform(“JSONPATH”, “$.pompaCO”, json))
if (COpompa.state == 0){
postUpdate(pompaCO, OPEN)
if (COpompa.state == 1){
postUpdate(pompaCO, CLOSED)
var test = transform(“JSONPATH”,"$.WentStrych",json)
println(test)
postUpdate(wentylStrychN, transform("JSONPATH", "$.WentStrych", json))
if (wentylStrychN.state == 0){
//postUpdate(wentylStrych, OPEN)
sendCommand(wentylStrych, OPEN)
if (wentylStrychN.state == 1){
//postUpdate(wentylStrych, CLOSED)
sendCommand(wentylStrych, CLOSED)
postUpdate(Swiatecznen, transform("JSONPATH", "$.Swiateczne", json))
if (Swiatecznen.state == 0){
sendCommand(Swiateczne, OPEN)
if (Swiatecznen.state == 1){
sendCommand(Swiateczne, CLOSED)
//postUpdate(minuty, transform("JSONPATH", "$.sunset", json))
//var int minutes = (minuty.state as DecimalType).intValue()
//logInfo("Test TV0", "Zarejestrowania ERRor")
//var DateTime startTime.postUpdate = now.getYear() + "-" + now.getMonthOfYear() + "-" + now.getDayOfMonth() + "T00:00:00")
//var DateTime startTime = parse(now.getYear() + "-" + now.getMonthOfYear() + "-" + now.getDayOfMonth() + "T00:00")
//logError("Test TV0", "sunset: " + startTime)
//startTime = startTime.plusMinutes(minutes)
//sunset.sendCommand(String::format("%02d:%02d", startTime.getHourOfDay(), startTime.getMinuteOfHour()))
//reguła drzwi garazowych
rule “GarrageDoor”
Item GarazDoor received command ON
sendHttpGetRequest(“http://192.168.1.177:8080/ustaw?nazwa:brama&noch”)
logInfo(“Garaz”, “Komenda uruchom - wysłana”)
//reguła podlewania ogrodu
rule “OgrodPodlewanieON”
Item Woda received command ON
sendHttpGetRequest(“http://192.168.1.177:8080/ustaw?nazwa:wodaON&noch”)
logInfo(“Woda”, “Komenda uruchom - wysłana”)
rule “OgrodPodlewanieOFF”
Item Woda received command OFF
sendHttpGetRequest(“http://192.168.1.177:8080/ustaw?nazwa:wodaOFF&noch”)
logInfo(“Woda”, “Komenda Wyłącz - wysłana”)
//reguła odczyt parametrów
rule “Startup_”
//System started or
Item Param_pob received command ON or
Time cron “0 0 1 * * ?” //aktualizacja parametrów zawsze o 1:00:00
var String json = sendHttpGetRequest(“http://192.168.1.177:8080/json_param&nocha”)
postUpdate(korekta, transform(“JSONPATH”,"$.korekta",json))
postUpdate(oswietleniezal, transform(“JSONPATH”,"$.oswietleniezal",json))
postUpdate(TempMinCO, transform(“JSONPATH”,"$.tempzalCO",json))
postUpdate(TempKomfort, transform(“JSONPATH”,"$.komfort",json))
postUpdate(TempEco, transform(“JSONPATH”,"$.eco",json))
postUpdate(TempZalWent, transform(“JSONPATH”,"$.tempZalWent",json))
postUpdate(tempWentStrych, transform(“JSONPATH”,"$.tempWentStrych",json))
postUpdate(wentylzal, transform(“JSONPATH”,"$.wentylzal",json))
postUpdate(wentylwyl, transform(“JSONPATH”,"$.wentylwyl",json))
postUpdate(setBojler, transform(“JSONPATH”,"$.bojler",json))
postUpdate(ONrano, transform(“JSONPATH”,"$.ONranoKomfort",json))
postUpdate(OFFrano, transform(“JSONPATH”,"$.OFFranoKomfort",json))
postUpdate(ONwieczor, transform(“JSONPATH”,"$.ONwieczorKomfort",json))
postUpdate(OFFwieczor, transform(“JSONPATH”,"$.OFFwieczorKomfort",json))
postUpdate(ONWeekend, transform(“JSONPATH”,"$.ONweekendKomfort",json))
postUpdate(OFFWeekend, transform(“JSONPATH”,"$.OFFweekendKomfort",json))
postUpdate(ONTV1, transform(“JSONPATH”,"$.TzalTV0",json))
postUpdate(OFFTV1, transform(“JSONPATH”,"$.TwylTV0",json))
postUpdate(ONTV2, transform(“JSONPATH”,"$.TzalTV1",json))
postUpdate(OFFTV2, transform(“JSONPATH”,"$.TwylTV1",json))
postUpdate(ONFish, transform(“JSONPATH”,"$.Tzalr",json))
postUpdate(OFFFish, transform(“JSONPATH”,"$.Twylr",json))
postUpdate(ONLED, transform(“JSONPATH”,"$.ONLED",json))
postUpdate(OFFLED, transform(“JSONPATH”,"$.OFFLED",json))
postUpdate(ONsw, transform(“JSONPATH”,"$.ONsw",json))
postUpdate(OFFsw, transform(“JSONPATH”,"$.OFFsw",json))
postUpdate(tempMinPieca, transform(“JSONPATH”,"$.tempMinPieca",json))
postUpdate(zalswiateczne, transform(“JSONPATH”,"$.zalswiateczne",json))
postUpdate(Param_pob, OFF)
