Problem with stability of Insteon on OH 4.3.2
jeshab Jeremy,
Thanks for getting back with me.
Glad I could help.
I do have a “system in the wild” that does trigger some issues.
My “TestOh” system is powered down. but, I can bring it back quickly.
IF you would like logs, or have additional testing, THEN let me know.
  • Correct, after 20 minutes (and no channels), all but two devices were online.
  • Correct-ish: marked as “Error: Comm” instead of “online”
    Also marked “Config Pending” (when it had been “online”)
  • I am assuming anything other than “online” means it is “offline”
  • Lot of noise:
    A mix of old and new devices means some devices only have power lines for communication.
    They would be “less reliable” than “dual band”…
    but, due to Insteon redundancy and (4 X re-broadcasting )
    they have always worked VERY reliably
    THAT is why some folks are so fond of Insteon… even now.
  • I was a bit surprised that “unknown” devices with no channels
    immediately changes state when I plugged it in closer to the hub. (No action by me)
    I really expected that to be part of the “5 minute cycle”.. or “offline/online” it.
  • Online devices that did NOT respond:
    I only configured 5 channels…
    It is common for a newly added device to be unresponsive. Cycling OH usually fixed that.
    In this case, a working device stopped working. THAT is unusual.
    Not slow, it would not respond at all. ¯_(ツ)_/¯
    Office: 2486DWH8 (6 or 8 key keypad)
    SpareRoom: 2476D (dimmer switch)
    Desk: 2457D2 (smart plug “lamp Linc dimmer”)
    “Desk” was the device that “hung”.
    Even buttons on the device would not work.
  • Correct: thermostat testing worked very well.
    Thermostat’s are only “wireless”. I only setup the “heat” channel…
    BUT that worked very well. Let me know if you would like further testing.
