2020-05-21 16:54:14.983 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 7: Retry count exceeded. Discarding message: TID 140: [CANCELLED] priority=Get, requiresResponse=true, callback: 211
2020-05-21 16:54:14.986 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 7: Got an event from Z-Wave network: ZWaveNodeStatusEvent
2020-05-21 16:54:14.989 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 7: Setting OFFLINE
2020-05-21 16:54:14.995 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 7: Node Status event - Node is DEAD
2020-05-21 16:54:14.997 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 7: Node is DEAD.
2020-05-21 16:54:14.999 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 7: Got an event from Z-Wave network: ZWaveNodeStatusEvent
2020-05-21 16:54:15.002 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 7: Setting OFFLINE
2020-05-21 16:54:15.003 [hingStatusInfoChangedEvent] - âzwave:device:16f41b43916:node7â changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Node is not communicating with controller
2020-05-21 16:54:15.008 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 7: Node Status event - Node is DEAD
2020-05-21 16:54:15.010 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 7: TID 140: Transaction completed
2020-05-21 16:54:15.013 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 7: notifyTransactionResponse TID:140 CANCELLED
2020-05-21 16:54:15.021 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 7: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2020-05-21 16:54:15.034 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 7: Sending REQUEST Message = 01 0D 00 13 07 06 60 0D 01 02 31 04 25 D4 4A
2020-05-21 16:54:15.064 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 7: sentData successfully placed on stack.
2020-05-21 16:54:15.068 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 7: TID 141: Transaction not completed
2020-05-21 16:54:15.167 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 7: SendData Request. CallBack ID = 212, Status = Transmission complete and ACK received(0)
2020-05-21 16:54:15.170 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 7: Got an event from Z-Wave network: ZWaveNodeStatusEvent
2020-05-21 16:54:15.171 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 7: Setting ONLINE
2020-05-21 16:54:15.176 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 7: Node Status event - Node is ALIVE
2020-05-21 16:54:15.177 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 7: Node is ALIVE. Init stage is DONE.
2020-05-21 16:54:15.179 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 7: Got an event from Z-Wave network: ZWaveNodeStatusEvent
2020-05-21 16:54:15.181 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 7: Setting ONLINE
2020-05-21 16:54:15.183 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 7: Node Status event - Node is ALIVE
2020-05-21 16:54:15.187 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 7: TID 141: Transaction not completed
2020-05-21 16:54:15.190 [hingStatusInfoChangedEvent] - âzwave:device:16f41b43916:node7â changed from OFFLINE (COMMUNICATION_ERROR): Node is not communicating with controller to ONLINE
2020-05-21 16:54:17.117 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 7: Application Command Request (ALIVE:DONE)
2020-05-21 16:54:17.119 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 7: resetResendCount initComplete=true isDead=false
2020-05-21 16:54:17.121 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 7: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
2020-05-21 16:54:17.124 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 7: Incoming command class COMMAND_CLASS_SENSOR_MULTILEVEL, endpoint 2
2020-05-21 16:54:17.126 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 7: SECURITY not supported
So it seams the the Node has connectivity problems. This really wonders becuase this node is only 10 meters away from the AEON Labs USB stick. I have another Steinel IS140-2 which is around 20 meters away but this one has no communication problems.
