I have these messages in openhab.log several times for different nodes of stella-z thermostat:
2016-12-08 09:53:04.700 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update ‘19.5’ for item ‘Thermostat_Wohnzimmer_Temp’ to handler for channel ‘zwave:device:92da143a:node52:sensor:temperature’, because no thing with the UID ‘zwave:device:92da143a:node52:sensor’ could be found.
But there is only the sensor_temperature channel and no thing with :sensor
Is there a problem with my item definition?
Number Thermostat_Wohnzimmer_Temp "Wohnzimmer Temperatur: [%.1f C]" <temperature> (gHeating, gHeatingEG) {channel="zwave:device:92da143a:node52:sensor_temperature"}
Number Thermostat_Wohnzimmer_Batterie "Wohnzimmer Batterie: [%d %%]" <energy> (gHeating, gHeatingEG) {channel="zwave:device:92da143a:node52:battery-level"}
Number Thermostat_Wohnzimmer_Modus "Wohnzimmer Heizungsmodus" <energy> (gHeating, gHeatingDG) {channel="zwave:device:92da143a:node52:thermostat_mode"}
Number Thermostat_Wohnzimmer_SetPoint "Wohnzimmer Solltemperatur [%.1f C]" <temperature> (gHeating, gHeatingEG) {channel="zwave:device:92da143a:node52:thermostat_setpoint_heating"}
