i installed the tado-binding (copied it to addons folder an created the .things, .items etc. as discribed in github), but alway get the following error in the openhab.log. Also the tado-thing is not shown in the thing-list in paperui.
ERROR - org.openhab.binding.tado
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.tado [228]
Unresolved requirement: Import-Package: com.google.gson; version=ā2.5.0ā
at org.eclipse.osgi.container.Module.start(Module.java:434)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1562)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1476)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
2017-03-16 20:25:11.413 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update ā56.00ā for item āHumidityā to handler for channel ātado:thermostat:home:humidityā, because no thing with the UID ātado:thermostat:homeā could be found.
Can you help me to get this binding running?
Thanks a lot!
