Problem with the rules. Heating rule
Hello. Just started learning Openhab. And everything was fine until I got to the rules. I’m not a programmer, so I did it using examples.
rule "Ventilation control"
Item FF_Bathroom_Humidity changed
if (FF_Bathroom_Humidity.state >= 70) FF_Bathroom_Fan.sendCommand(ON)
else if (FF_Bathroom_Humidity.state <= 60) FF_Bathroom_Fan.sendCommand(OFF)
Fan control by air humidity. Everything works. Depending on the humidity, MQTT sends commands to turn the fan on or off.
By analogy, I wanted to make heating control. But the command to turn on or off the heating from the MQTT broker is not received. I look in MQTT. FX
rule "Heating control"
Item FF_Bathroom_HeatingSet changed
or
Item FF_Bathroom_Heating changed to ON
or
Item FF_Bathroom_Temperature changed
if (FF_Bathroom_Heating.state == ON)
	if (FF_Bathroom_Temperatur.state >= FF_Bathroom_HeatingSet.state) FF_Bathroom_ThermalHead.sendCommand(OFF)
	else if (FF_Bathroom_Temperatur.state < FF_Bathroom_HeatingSet.state) FF_Bathroom_ThermalHead.sendCommand(ON)
Items
Switch          FF_Bathroom_Heating                 "Heating On Off"               <switch>          (FF_Bathroom, gHeating)           ["HVAC", "Switchable"]             {channel=""}
Switch          FF_Bathroom_ThermalHead             "Thermal head"            <switch>          (FF_Bathroom, gHeating)           ["Switchable"]                     {channel=""}
Number          FF_Bathroom_HeatingSet              "Temperature setting"   <heat>            (FF_Bathroom, gHeating)           ["HVAC"]                           {channel=""}
Number          FF_Bathroom_Temperature             "Temperature sensor"      <temperature>     (FF_Bathroom, gTemperature)       ["Temperature"]                    {channel=""}
Sitemap
Frame {
		Default item=FF_Bathroom_Temperature  label="Temperature"
		Default item=FF_Bathroom_Heating label="Heating On Off"
		Setpoint item=FF_Bathroom_HeatingSet label="Temperature setting"
		visibility=[FF_Bathroom_Heating==ON]
Topics for MQTT I write using Paper UI. Please tell me what I did wrong? Why don’t I get a command to turn the heating on and off? Second day problem. Sorry for my English. Thanks
  • Platform information:
    • Hardware: Raspberry Pi 3
    • OS: Raspbian Buster Lite
    • Java Runtime Environment: Zulu Embedded 8.25.0.76
    • openHAB version: 2.5.3
What does the event.log say? Do you see a event happen?
Secondly, If you turn of the heating (FF_Bathroom_Heating to OFF), nothing will happen, because of Item FF_Bathroom_Heating changed to ON`
My suggestion to your rule would be:
or
Item FF_Bathroom_Heating received update
or
	else
else  /// FF_Bathroom_Heating != ON
