I have developed a binding.
It works prefect in Windows10 IDE
It build without errors
But when i move it to my RPI3 OH2.4 Stable i receive this error.
2019-01-21 23:15:26.554 [WARN ] [ig.xml.osgi.XmlDocumentBundleTracker] - The XML document '/ESH-INF/thing/thing-types.xml' in module 'org.openhab.binding.smhi' could not be parsed: : ParseError at [row,col]:[201,22]
Message: /var/lib/openhab2/cache/org.eclipse.osgi/314/0/bundleFile : : ParseError at [row,col]:[201,22]
---- Debugging information ----
message : : ParseError at [row,col]:[201,22]
cause-exception : com.thoughtworks.xstream.io.StreamException
cause-message : : ParseError at [row,col]:[201,22]
class : org.eclipse.smarthome.config.xml.util.NodeValue
required-type : org.eclipse.smarthome.config.xml.util.NodeValue
converter-type : org.eclipse.smarthome.config.xml.util.NodeValueConverter
path : /thing-descriptions/channel-type[13]/item-type
line number : 201
class[1] : java.util.ArrayList
converter-type[1] : com.thoughtworks.xstream.converters.collections.CollectionConverter
class[2] : org.eclipse.smarthome.core.thing.xml.internal.ChannelTypeXmlResult
converter-type[2] : org.eclipse.smarthome.core.thing.xml.internal.ChannelTypeConverter
class[3] : org.eclipse.smarthome.core.thing.xml.internal.ThingDescriptionList
converter-type[3] : org.eclipse.smarthome.core.thing.xml.internal.ThingDescriptionConverter
version : 1.4.7
can’t find any errors in thing-types-xml
<?xml version="1.0" encoding="UTF-8"?>
<thing:thing-descriptions bindingId="smhi"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:thing="http://eclipse.org/smarthome/schemas/thing-description/v1.0.0"
xsi:schemaLocation="http://eclipse.org/smarthome/schemas/thing-description/v1.0.0 http://eclipse.org/smarthome/schemas/thing-description-1.0.0.xsd">
<thing-type id="weather-and-forecast">
<label>SMHI Weather And Forecast</label>
<description>Provides current weather and forecast data from the SMHI API.</description>
<channel-groups>
<channel-group typeId="weather" id="current"></channel-group>
<channel-group id="forecastTomorrow" typeId="dailyForecast">
<label>Tomorrows Forecast</label>
<description>This is the weather forecast for tomorrow.</description>
</channel-group>
<channel-group id="forecastDay2" typeId="dailyForecast">
<label>2 Day Forecast</label>
<description>This is the weather forecast in two days.</description>
</channel-group>
<channel-group id="forecastDay3" typeId="dailyForecast">
<label>3 Day Forecast</label>
<description>This is the weather forecast in three days.</description>
</channel-group>
</channel-groups>
<config-description>
<parameter name="weatherlocation" type="text">
<label>Location</label>
<description>Location of weather in lat,lon coordinates. Defauls to Stockholm Castle</description>
<required>true</required>
<default>59.322665376,18.069666388</default>
</parameter>
<parameter name="refresh" type="text">
<label>Refresh Interval</label>
<description>Specifies the refresh interval in minutes.</description>
<default>60</default>
</parameter>
</config-description>
</thing-type>
<channel-group-type id="weather">
<label>Current Weather</label>
<channels>
<channel id="time-stamp" typeId="time-stamp" />
<channel id="condition" typeId="condition" />
<channel id="condition-id" typeId="Wsymb2" />
<channel id="temperature" typeId="system.outdoor-temperature" />
<channel id="min-temperature" typeId="min-temperature" />
<channel id="max-temperature" typeId="max-temperature" />
<channel id="pressure" typeId="msl" />
<channel id="humidity" typeId="system.atmospheric-humidity" />
<channel id="wind-speed" typeId="ws" />
<channel id="wind-direction" typeId="wd" />
<channel id="wind-gust" typeId="gust" />
<channel id="thunderstorm" typeId="tstm" />
<channel id="cloud-cover" typeId="tcc_mean" />
<channel id="cloud-over-low" typeId="lcc_mean" />
<channel id="cloud-cover-medium" typeId="mcc_mean" />
<channel id="cloud-cover-high" typeId="hcc_mean" />
<channel id="visibility" typeId="vis" />
<channel id="precipitation-cat" typeId="pcat" />
<channel id="precipitation-mean" typeId="pmean" />
<channel id="precipitation-median" typeId="pmedian" />
<channel id="precipitation-min" typeId="pmin" />
<channel id="precipitation-max" typeId="pmax" />
<channel id="precipitation-frozen" typeId="spp" />
</channels>
</channel-group-type>
<channel-group-type id="dailyForecast">
<label>Daily Forecast</label>
<description>This is the 3 day / daily weather forecast.</description>
<channels>
<channel id="time-stamp" typeId="daily-forecast-time-stamp" />
<channel id="condition" typeId="forecasted-condition" />
<channel id="temperature" typeId="forecasted-t" />
<channel id="min-temperature" typeId="forecasted-min-temperature" />
<channel id="max-temperature" typeId="forecasted-max-temperature" />
<channel id="pressure" typeId="forecasted-msl" />
<channel id="humidity" typeId="forecasted-r" />
<channel id="wind-speed" typeId="forecasted-ws" />
<channel id="wind-direction" typeId="forecasted-wd" />
<channel id="wind-gust" typeId="forecasted-gust" />
<channel id="thunderstorm" typeId="forecasted-tstm" />
<channel id="cloud-cover" typeId="forecasted-tcc_mean" />
<channel id="cloud-cover-low" typeId="forecasted-lcc_mean" />
<channel id="cloud-cover-medium" typeId="forecasted-mcc_mean" />
<channel id="cloud-cover-high" typeId="forecasted-hcc_mean" />
<channel id="visibility" typeId="forecasted-vis" />
<channel id="precipitation-cat" typeId="forecasted-pcat" />
<channel id="precipitation-mean" typeId="forecasted-pmean" />
<channel id="precipitation-median" typeId="forecasted-pmedian" />
<channel id="precipitation-min" typeId="forecasted-pmin" />
<channel id="precipitation-max" typeId="forecasted-pmax" />
<channel id="precipitation-frozen" typeId="forecasted-spp" />
</channels>
<channel-type id="time-stamp">
<item-type>DateTime</item-type>
<label>Observation Time</label>
<description>Time of data observation.</description>
<category>Time</category>
<state readOnly="true" pattern="%1$tY-%1$tm-%1$td %1$tH:%1$tM:%1$tS" />
</channel-type>
<channel-type id="daily-forecast-time-stamp">
<label>Forecast Date</label>
<description>Date of data forecasted.</description>
<state readOnly="true" pattern="%1$tY-%1$tm-%1$td" />
</channel-type>
<channel-type id="condition">
<item-type>String</item-type>
<label>Weather Condition</label>
<description>Current weather condition.</description>
<category>Sun_Clouds</category>
<state readOnly="true" />
</channel-type>
<channel-type id="forecasted-condition">
<label>Forecasted Weather Condition</label>
<description>Forecasted weather condition.</description>
</channel-type>
<channel-type id="Wsymb2" advanced="true">
<item-type>Number</item-type>
<label>Weather Condition Id</label>
<description>Id of the weather condition.</description>
</channel-type>
<channel-type id="forecasted-t">
<item-type>Number:Temperature</item-type>
<label>Forecasted Temperature</label>
<description>Forecasted outdoor temperature.</description>
<category>Temperature</category>
<state readOnly="true" pattern="%.1f %unit%" />
</channel-type>
<channel-type id="min-temperature">
<label>Min Temperature</label>
<description>Min outdoor temperature rest of day.</description>
</channel-type>
<channel-type id="max-temperature">
<label>Max Temperature</label>
<description>Max outdoor temperature rest of day.</description>
</channel-type>
<channel-type id="forecasted-min-temperature">
<label>Forecasted Min Temperature</label>
<description>Forecasted min outdoor temperature.</description>
</channel-type>
<channel-type id="forecasted-max-temperature">
<label>Forecasted Max Temperature</label>
<description>Forecasted max outdoor temperature.</description>
</channel-type>
<channel-type id="msl">
<item-type>Number:Pressure</item-type>
<label>Forecasted Pressure</label>
<description>Barometric pressure.</description>
<category>Pressure</category>
</channel-type>
<channel-type id="forecasted-msl">
<description>Forecasted barometric pressure.</description>
</channel-type>
<channel-type id="forecasted-r">
<item-type>Number:Dimensionless</item-type>
<label>Forecasted Humidity</label>
<description>Forecasted atmospheric relative humidity.</description>
<category>Humidity</category>
<state readOnly="true" pattern="%.0f %%" />
</channel-type>
<channel-type id="ws">
<item-type>Number:Speed</item-type>
<label>Forecasted Wind Speed</label>
<description>Forecasted wind speed.</description>
<category>Wind</category>
<state readOnly="true" pattern="%.1f m/s" />
</channel-type>
<channel-type id="forecasted-ws">
</channel-type>
<channel-type id="wd">
<item-type>Number:Angle</item-type>
<label>Forecasted Wind Direction</label>
<description>Forecasted wind direction expressed as an angle.</description>
<state readOnly="true" pattern="%.0f %unit%" />
</channel-type>
<channel-type id="forecasted-wd">
</channel-type>
<channel-type id="gust" advanced="true">
<label>Gust Speed</label>
<description>Current gust speed.</description>
</channel-type>
<channel-type id="forecasted-gust" advanced="true">
<label>Forecasted Gust Speed</label>
<description>Forecasted gust speed.</description>
</channel-type>
<channel-type id="tstm" advanced="true">
<label>Thunder probability</label>
<description>Thunder probability.</description>
<category>Energy</category>
</channel-type>
<channel-type id="forecasted-tstm" advanced="true">
<label>Forecasted Thunder probability</label>
<description>Forecasted thunder probability.</description>
</channel-type>
<channel-type id="tcc_mean">
<label>Cloud Cover</label>
<description>The total cloud cover. How big part of the sky is covered by clouds.</description>
<category>Clouds</category>
<state readOnly="true" min="0" max="100" pattern="%.1f %%" />
</channel-type>
<channel-type id="forecasted-tcc_mean">
<label>Forecasted Cloud Cover</label>
<description>Forecasted value of total cloud cover.</description>
</channel-type>
<channel-type id="lcc_mean" advanced="true">
<label>Cloud Cover Low</label>
<description>Low cloud cover. Clouds between 0 and 2500 meters.</description>
</channel-type>
<channel-type id="forecasted-lcc_mean" advanced="true">
<label>Forecasted Cloud Cover Low</label>
<description>Forecasted low cloud cover. Clouds between 0 and 2500 meters.</description>
</channel-type>
<channel-type id="mcc_mean" advanced="true">
<label>Cloud Cover Medium</label>
<description>Medium cloud cover. Clouds between 2500 and 6000 meters.</description>
</channel-type>
<channel-type id="forecasted-mcc_mean" advanced="true">
<label>Forecasted Cloud Cover Medium</label>
<description>Forecasted medium cloud cover. Clouds between 2500 and 6000 meters.</description>
</channel-type>
<channel-type id="hcc_mean" advanced="true">
<label>Cloud Cover High</label>
<description>High cloud cover. Clouds above 6000 meters.</description>
</channel-type>
<channel-type id="forecasted-hcc_mean" advanced="true">
<label>Forecasted Cloud Cover High</label>
<description>Forecasted high cloud cover. Clouds above 6000 meters.</description>
</channel-type>
<channel-type id="vis" advanced="true">
<item-type>Number:Length</item-type>
<label>Visibility</label>
<description>Horizontal visibility.</description>
<state readOnly="true" pattern="%d km" />
</channel-type>
<channel-type id="forecasted-vis" advanced="true">
<label>Forecasted Visibility</label>
<description>Forecasted horizontal visibility.</description>
</channel-type>
<channel-type id="pcat">
<label>Precipitation Category</label>
<description>Precipitation category.</description>
<category>Rain</category>
</channel-type>
<channel-type id="forecasted-pcat">
<label>Forecasted Precipitation Category</label>
<description>Forecasted precipitation category.</description>
</channel-type>
<channel-type id="pmean">
<label>Precipitation Mean</label>
<description>Mean precipitation intensity.</description>
<state readOnly="true" pattern="%.1f mm/h" />
</channel-type>
<channel-type id="forecasted-pmean">
<label>Forecasted Precipitation Mean</label>
<description>Forecasted mean precipitation intensity.</description>
</channel-type>
<channel-type id="pmedian" advanced="true">
<label>Precipitation Median</label>
<description>Median precipitation intensity.</description>
</channel-type>
<channel-type id="forecasted-pmedian" advanced="true">
<label>Forecasted Precipitation Median</label>
<description>Forecasted median precipitation intensity.</description>
</channel-type>
<channel-type id="pmin" advanced="true">
<label>Precipitation Min</label>
<description>Min precipitation intensity.</description>
</channel-type>
<channel-type id="forecasted-pmin" advanced="true">
<label>Forecasted Precipitation Min</label>
<description>Forecasted min precipitation intensity.</description>
</channel-type>
<channel-type id="pmax" advanced="true">
<label>Precipitation Max</label>
<description>Max precipitation intensity.</description>
</channel-type>
<channel-type id="forecasted-pmax" advanced="true">
<label>Forecasted Precipitation Max</label>
<description>Forecasted max precipitation intensity.</description>
</channel-type>
<channel-type id="spp" advanced="true">
<label>Precipitation in frozen form</label>
<description>Percent of precipitation in frozen form.</description>
</channel-type>
<channel-type id="forecasted-spp" advanced="true">
<label>Forecasted Precipitation in frozen form</label>
<description>Forecasted percent of precipitation in frozen form.</description>
</channel-type>
</thing:thing-descriptions>
/Mike
