Hi.
I’ve a ZD2102-5 that worked perfectly until i had to reset my z-wave USB controller and re-add all my devices. this device in particular is now correctly added to my network, but the items are not recieving any update from the node. ANyone with the same problem?
Check your association group (should be set to the controller), check if you have the correct channels linked to your items:
https://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/713
https://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/816
Tnk!
Added new contact item to the channel and update the association group. now it give me update only when i close the door
