Hi, Am using Yale lock and it works without issues. z wave binding 2.4.
I thing the key is having a network security key and also including the entry control device as secure.
This worked for me.
and if you’re doing a Pi and z-stick setup, physically move your Pi to near the lock while doing the inclusion.
Plus (from “eye of newt, toe of frog” personal experience) if there has been a failed inclusion – delete from OH, including deleting any referencing items. Stop OH, run “openhabian-cli clean-cache”, reset the lock, then start up OH near the lock and go thru the inclusion process from Habmin. The stick MAY still retain the node number from the prior failed include, but this does not seem to matter if you clean up the “other stuff”.
Thanks guys, had to buy a 10 meter USB extention since i am running OH on a HPE server in the attic But when turning on “Low Power Inclusion” and having the stick very close it was able to include it with security
