I tried to update my manual installation. I used the published documentation with the necessary commands. After all commands wee submitted my openhab service will not start again. I have no access to web ui.
Following log is for you.
After reboot service and reboot pi
pi@raspberrypi:~ $ sudo systemctl status openhab2.service
* openhab2.service - The openHAB 2 Home Automation Bus Solution
Loaded: loaded (/lib/systemd/system/openhab2.service; enabled)
Active: active (running) since Fr 2017-02-03 16:48:15 CET; 334ms ago
Docs: http://docs.openhab.org
Process: 17186 ExecStop=/bin/kill -SIGINT $MAINPID (code=exited, status=1/FAIL URE)
Main PID: 17189 (karaf)
CGroup: /system.slice/openhab2.service
|-17189 /bin/bash /opt/openhab2/runtime/bin/karaf server
|-17212 /bin/bash /opt/openhab2/runtime/bin/karaf server
|-17213 /bin/bash /opt/openhab2/runtime/bin/karaf server
|-17214 /bin/bash /opt/openhab2/runtime/bin/karaf server
|-17229 /bin/bash /opt/openhab2/runtime/bin/karaf server
|-17234 /bin/bash /opt/openhab2/runtime/bin/karaf server
|-17239 /bin/bash /opt/openhab2/runtime/bin/karaf server
|-17245 /bin/bash /opt/openhab2/runtime/bin/karaf server
|-17250 /bin/bash /opt/openhab2/runtime/bin/karaf server
|-17259 /bin/bash /opt/openhab2/runtime/bin/karaf server
`-17264 /bin/bash /opt/openhab2/runtime/bin/karaf server
Feb 03 16:48:15 raspberrypi systemd[1]: Starting The openHAB 2 Home Automati....
Feb 03 16:48:15 raspberrypi systemd[1]: Started The openHAB 2 Home Automatio....
Feb 03 16:48:15 raspberrypi start.sh[17189]: Launching the openHAB runtime...
Hint: Some lines were ellipsized, use -l to show in full.
After cold reboot
Active: active (running) since Fr 2017-02-03 16:53:14 CET; 1s ago
Process: 4582 ExecStop=/bin/kill -SIGINT $MAINPID (code=exited, status=1/FAILURE)
Main PID: 4585 (karaf)
|-4585 /bin/bash /opt/openhab2/runtime/bin/karaf server
|-4720 /bin/bash /opt/openhab2/runtime/bin/karaf server
|-4721 /usr/bin/java -version
|-4722 grep -E "([0-9].[0-9]\..*[0-9]).*"
|-4723 awk {print substr($3,2,length($3)-2)}
|-4724 awk {print substr($1, 3, 3)}
`-4725 sed -e s;\.;;g
Feb 03 16:53:14 raspberrypi systemd[1]: Starting The openHAB 2 Home Automati....
Feb 03 16:53:14 raspberrypi systemd[1]: Started The openHAB 2 Home Automatio....
Feb 03 16:53:14 raspberrypi start.sh[4585]: Launching the openHAB runtime...
retry after few minutes
Active: active (running) since Fr 2017-02-03 16:56:42 CET; 1s ago
Process: 14242 ExecStop=/bin/kill -SIGINT $MAINPID (code=exited, status=1/FAILURE)
Main PID: 14245 (karaf)
|-14245 /bin/bash /opt/openhab2/runtime/bin/karaf server
|-14354 /usr/bin/java -version
`-14355 grep ^IBM
Feb 03 16:56:42 raspberrypi systemd[1]: Started The openHAB 2 Home Automatio....
Feb 03 16:56:42 raspberrypi start.sh[14245]: Launching the openHAB runtime...
What is wrong in my system now? Are there any hints for me?
Thanks in advance.
