I just enabled ZRAM on my Raspberry Pi 3 Model B Plus Rev 1.3 through openhabian-config. Previously I have configured the Amanda backup, and the openHAB backup script. Just to be safe, I rebooted after the installation in this way:
[20:39:34] openhabian@openhab:~$ sudo systemctl stop openhab2
[20:40:17] openhabian@openhab:~$ sudo zram-config stop
umount: /var/log: target is busy
(In some cases useful info about processes that
use the device is found by lsof(8) or fuser(1).)
Warning: Stopping rsyslog.service, but it can still be activated by:
syslog.socket
/usr/local/bin/zram-config: line 158: echo: write error: Device or resource busy
umount: /var/lib/openhab2 (overlay1) unmounted
[20:40:56] openhabian@openhab:~$ sudo shutdown -r now
Should I be worried about /usr/local/bin/zram-config: line 158: echo: write error: Device or resource busy
? Where the mentioned device is /sys/class/zram-control/hot_remove
My Pi is up again and everything seems fine.
[20:44:13] openhabian@openhab:~$ zramctl
NAME ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT
/dev/zram0 lz4 600M 4K 76B 4K 4 [SWAP]
/dev/zram1 lz4 600M 25.5M 3.3M 3.9M 4 /opt/zram/zram1
/dev/zram2 lzo 500M 34M 5.5M 6.2M 4 /opt/zram/zram2
