on the fritzbox side i created a user
openhab
and the rights are for (FRITZ!Box Einstellungen) (prachnachrichten, Faxnachrichten, FRITZ!App Fon und Anrufliste) (Smart Home)
As fritzboxtr0641 is an openHAB1 Binding, I doubt that there is any option to set its configuration via GUI. That is the reason why the file openHAB2-conf\services\fritzboxtr064.cfg is generated. You have to change the settings in this file.
Please post your openHAB2-conf\services\fritzboxtr064.cfg here (using code fences)
It’s ok to xxx the password
1 ## Binding for accessing FritzBoxes using the TR064 protocol. Uses http(s) requests.
2
3 # URL. Either use http://:49000 or https://:49443 (https preferred!)
4 url=http://10.147.42.1:49000
5
6 # Refresh Interval (60000ms default)
7 #refresh=60000
8
9 # User Name (only use this value if you configured a user in fbox webui/config!)
10 # If this parameter is missing, “dslf-config” is used as default username
11 # It is recommended to to switch to authentication by username in fritzbox config
12 # and add a separate config user for this binding.
13 user=openhab
14
15 # PW
16 pass=mypassword
You must not add line numbers. you must not add spaces at the beginning of a parameter. So the file should be more like /etc/openhab2/services/fritzboxtr064.cfg
#refresh=60000
user=openhab
# PW
pass=mypassword
ok yes looks better how did you do it with? the preformated or blockquote
but still with this information should be a conection to the fritzbox and this should be visible on the log file
when i do some change on the cfg file i got a error
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:146) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) [82:org.eclipse.jetty.security:9.4.11.v20180605]
at jdk.internal.reflect.GeneratedMethodAccessor87.invoke(Unknown Source) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.invokeMethod(BaseMethod.java:228) ~[39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.access$500(BaseMethod.java:41) ~[39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.inject.methods.BaseMethod$Resolved.invoke(BaseMethod.java:664) ~[39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.invoke(BaseMethod.java:510) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.inject.methods.ActivateMethod.invoke(ActivateMethod.java:317) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.inject.methods.ActivateMethod.invoke(ActivateMethod.java:307) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:334) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:114) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:947) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:919) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:741) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.reconfigure(SingleComponentManager.java:708) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.SingleComponentManager.reconfigure(SingleComponentManager.java:647) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.configurationUpdated(ConfigurableComponentHolder.java:435) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.RegionConfigurationSupport.configurationEvent(RegionConfigurationSupport.java:288) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.RegionConfigurationSupport$1.configurationEvent(RegionConfigurationSupport.java:91) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.cm.impl.ConfigurationManager$FireConfigurationEvent.sendEvent(ConfigurationManager.java:1667) [9:org.apache.felix.configadmin:1.9.4]
at org.apache.felix.cm.impl.ConfigurationManager$FireConfigurationEvent.run(ConfigurationManager.java:1635) [9:org.apache.felix.configadmin:1.9.4]
at org.apache.felix.cm.impl.UpdateThread$1.run(UpdateThread.java:126) [9:org.apache.felix.configadmin:1.9.4]
at org.apache.felix.cm.impl.UpdateThread$1.run(UpdateThread.java:123) [9:org.apache.felix.configadmin:1.9.4]
at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:122) [9:org.apache.felix.configadmin:1.9.4]
at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:105) [9:org.apache.felix.configadmin:1.9.4]
Caused by: java.lang.ClassNotFoundException: javax.xml.soap.SOAPException cannot be found by org.openhab.binding.fritzboxtr064_1.13.0
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:484) ~[?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:395) ~[?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:387) ~[?:?]
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:150) ~[?:?]
at java.lang.ClassLoader.loadClass(ClassLoader.java:521) ~[?:?]
... 28 more
2019-03-22 23:01:07.272 [vent.ItemStateChangedEvent] - fboxWanTotalBytesSent changed from 1612771547 to 1613084570
2019-03-22 23:01:07.279 [vent.ItemStateChangedEvent] - fboxWanTotalBytesReceived changed from 2053148440 to 2053217366
2019-03-22 23:01:07.284 [vent.ItemStateChangedEvent] - fboxDslDownstreamMaxRate changed from 140263 to 140607
2019-03-22 23:01:07.289 [vent.ItemStateChangedEvent] - fboxWanLayer1DownstreamMaxBitRate changed from 140607000 to 140
Ah. So there is only some information missing. Maybe your box isn’t fully supported. Another option would be the firmware version (possible changed options…)
No, that’s normal behavior. The logger name is truncated. It starts with org.openhab.binding. and it’s very likely you will never see this in a log file…
