Problems controlling my milight bulb
Success!
Thanks for your responses Hans-Jorg. It was actually a Milight bridge (although it was a dodgy photo). The problem was the IP address. My router DHCP list only showed one device I didn’t recognise so I assumed that was it. Actually, it wasn’t. I used an app on my phone called Fing to do a survey of the IP addresses and found the bridge made by “Hi-Flying electronics technology”. Once I plugged in the correct IP address, it worked!
I hope this helps others.
Cheers,
Trevor.
@hmerk I can’t configure disco mode for separated lights. I want to do the same disco mode for 2 lamps only, but I have 4 in the bridge.
Switch Luminaria_1		(LuminariasSala)		{milight="bridge1;7"}
Switch Luminaria_1w		(LuminariasSala_w)		{milight="bridge1;7;whiteMode"}
Color Luminaria_1rgb	(LuminariasSala_rgb)	{milight="bridge1;7;rgb"}
Dimmer Luminaria_1b		(LuminariasSala_b)		{milight="bridge1;7;brightness;27"}
Dimmer Luminaria_1dm	(LuminariasSala_dm)		{milight="bridge1;7;discoMode"}
Dimmer Luminaria_1ds	(LuminariasSala_ds)		{milight="bridge1;7;discoSpeed"}
Switch Luminaria_2		(LuminariasSala)		{milight="bridge1;8"}
Switch Luminaria_2w		(LuminariasSala_w)		{milight="bridge1;8;whiteMode"}
Color Luminaria_2rgb	(LuminariasSala_rgb)	{milight="bridge1;8;rgb"}
Dimmer Luminaria_2b		(LuminariasSala_b)		{milight="bridge1;8;brightness;27"}
Dimmer Luminaria_2dm	(LuminariasSala_dm)		{milight="bridge1;8;discoMode"}
Dimmer Luminaria_2ds	(LuminariasSala_ds)		{milight="bridge1;8;discoSpeed"}
Switch Luminaria_3			{milight="bridge1;9"}
Switch Luminaria_3w			{milight="bridge1;9;whiteMode"}
Color Luminaria_3rgb		{milight="bridge1;9;rgb"}
Dimmer Luminaria_3b			{milight="bridge1;9;brightness;27"}
Dimmer Luminaria_3dm		{milight="bridge1;9;discoMode"}
Dimmer Luminaria_3ds		{milight="bridge1;9;discoSpeed"}
Group:Switch:OR(ON, OFF) LuminariasSala		"Todas as Lampadas [(%d)]"
Group:Switch:OR(ON, OFF) LuminariasSala_w	"Todas as Lampadas [(%d)]"
Group:Dimmer LuminariasSala_b	"Brightness"
Group:Dimmer LuminariasSala_dm	"Disco Mode"
Group:Dimmer LuminariasSala_ds	"Disco Speed"
Group:Color LuminariasSala_rgb	"Colors"
	sendCommand(Luminaria_1w, ON)
    Thread::sleep(50)
    sendCommand(Luminaria_2w, ON)
    Thread::sleep(50)
    sendCommand(Luminaria_1dm, INCREASE)
    Thread::sleep(50)
    sendCommand(Luminaria_2dm, INCREASE)
I put a sleep time because sometimes it doesn’t receive both commands. Anyway, I can use the rule with “Luminaria_1dm” and “Luminaria_2dm” but it only starts disco mode in the lamp2. Very weird. In the milight app I can start disco mode in both lamps. I dont want to use “bridge1;6;discoMode” because I have another lamp in my bedroom that I don’t want to turn it on.
Can this openhab binding separate discomode and speed in the lamps at the same bridge?
@wender_reis this seems to be a bug in the binding. I will have a look at this issue after christmas.
Best
Hans-Jörg
Thanks for your support.
Merry Christmas.
Hi, do you have a solution for V5?
Unfortunately not. I wrote th 1.x binding version, but there will be no further development for this, as we have a 2.x version in place, written by @David_Graff.
