- Platform information:
- Hardware: Intel I7/16Gb RAM/ 400Gb HDD
- OS: Centos 7
- Java Runtime Environment: OpenJDK Runtime Environment (build 1.8.0_232-b09)
- openHAB version: 2.5.0-1
I have tried following the sample in the LIFX bindings page but with limited success. Have looked through a number of posts but unable to find out why my config is not working.
My related config files are as follows
/etc/openhab2/things/demo.things
Thing lifx:colorlight:living [ host="192.168.1.176" ]
/etc/openhab2/items/test.items
Color Living_Color { Channel="lifx:colorlight:living:color" }
Dimmer Living_Temperature { Channel="lifx:colorlight:living:temperature" }
/etc/openhab2/sitemaps/demo.sitemap
sitemap demo label="Main Menu"
Frame label="Living" {
Switch item=Living_Color
Slider item=Living_Color
Colorpicker item=Living_Color
Slider item=Living_Temperature
I have also installed the openhab iOS app and set it up.
With the above, in PaperUI, I have the following
Config/Bindings: I have LIFX Bindings installed
Config/Things: LIFX Color Light is online
Config/Items: Living_Temerature and Living_Color are displayed.
On the IOS app, I have a nice “LIVING” panel with the 4 various options available. I have set the brightness to full, color to white, temp to 100. Toggling the switch to on/off makes the switch toggle on the app, and in the local web browser in the HABPanel UI I have the same 4 options (though displayed slightly differently). Toggling the switch on iPhone or web page toggles the switch on both devices.
When toggling the switch on either device, I see the folloowing occur in the events.log file
2019-12-22 11:26:02.249 [ome.event.ItemCommandEvent] - Item 'Living_Color' received command OFF
2019-12-22 11:26:02.250 [vent.ItemStateChangedEvent] - Living_Color changed from 238,90,100 to 238,90,0
2019-12-22 11:26:15.395 [ome.event.ItemCommandEvent] - Item 'Living_Color' received command ON
2019-12-22 11:26:15.396 [vent.ItemStateChangedEvent] - Living_Color changed from 238,90,0 to 238,90,100
In the demo.things file I have been unable to get the LIFX to go online if I use the deviceId but it does go online when I use the IP address. I was able to confirm the IP and deviceId using a combo of the LIFX iPhone app and tcpdump.
Is there something I’m doing wrong here ?
