Since some weeks I have been making some tests with openHab 1.8.3 on a Linux VM on my Macbook. Everything works well so I wanted to migrate to my Raspberry Pi B+. I installed Raspbian Jessie lite, then oracle-jdk8 with apt-get install, then openHab (download, not with apt-get).
Now I copied the config-files from my VM to the raspberry and loaded the same addons as in the VM. I can see in the output that everyhing is booting (slower of course), but I can’t load the website, and the events.log is empty. In the openhab.log I see that the Netatmo-binding is connecting, but I don’t see any measured values.
Here are the outputs from start_debug.sh, does anyone see something?
pi@raspberrypi:~/openhab $ ./start_debug.sh
Launching the openHAB runtime in debug mode...
Listening for transport dt_socket at address: 8001
osgi> 21:23:06.274 [DEBUG] [.s.internal.SchedulerActivator:36 ] - Scheduler has been started.
21:23:07.165 [INFO ] [uartz.impl.StdSchedulerFactory:1175 ] - Using default implementation for ThreadExecutor
21:23:07.486 [INFO ] [rtz.core.SchedulerSignalerImpl:61 ] - Initialized Scheduler Signaller of type: class org.quartz.core.SchedulerSignalerImpl
21:23:07.495 [INFO ] [rg.quartz.core.QuartzScheduler:243 ] - Quartz Scheduler v.2.1.7 created.
21:23:07.520 [INFO ] [org.quartz.simpl.RAMJobStore :154 ] - RAMJobStore initialized.
21:23:07.543 [INFO ] [rg.quartz.core.QuartzScheduler:268 ] - Scheduler meta-data: Quartz Scheduler (v2.1.7) 'openHAB-job-scheduler' with instanceId 'NON_CLUSTERED'
Scheduler class: 'org.quartz.core.QuartzScheduler' - running locally.
NOT STARTED.
Currently in standby mode.
Number of jobs executed: 0
Using thread pool 'org.quartz.simpl.SimpleThreadPool' - with 2 threads.
Using job-store 'org.quartz.simpl.RAMJobStore' - which does not support persistence. and is not clustered.
21:23:07.554 [INFO ] [uartz.impl.StdSchedulerFactory:1324 ] - Quartz scheduler 'openHAB-job-scheduler' initialized from specified file: './etc/quartz.properties'
21:23:07.561 [INFO ] [uartz.impl.StdSchedulerFactory:1328 ] - Quartz scheduler version: 2.1.7
21:23:07.575 [INFO ] [rg.quartz.core.QuartzScheduler:534 ] - Scheduler openHAB-job-scheduler_$_NON_CLUSTERED started.
21:23:07.646 [DEBUG] [o.config.core.ConfigDispatcher:146 ] - Processing openHAB default configuration file '/home/pi/openhab/configurations/openhab_default.cfg'.
21:23:08.367 [DEBUG] [o.config.core.ConfigDispatcher:168 ] - Processing openHAB main configuration file '/home/pi/openhab/configurations/openhab.cfg'.
21:23:08.774 [DEBUG] [.o.core.internal.CoreActivator:93 ] - UUID file already exists at '/home/pi/openhab/webapps/static/uuid' with content '5e30b618-0b1f-4e53-8602-dacf889fc26d'
21:23:08.787 [DEBUG] [.o.core.internal.CoreActivator:115 ] - Created file '/home/pi/openhab/webapps/static/version' with content '1.8.3'
21:23:08.794 [INFO ] [.o.core.internal.CoreActivator:61 ] - openHAB runtime has been started (v1.8.3).
21:23:09.225 [DEBUG] [a.internal.AutoUpdateActivator:31 ] - AutoUpdate binding has been started.
21:23:28.648 [DEBUG] [.p.i.PersistenceModelActivator:23 ] - Registered 'persistence' configuration parser
21:23:28.887 [DEBUG] [.c.t.i.TransformationActivator:38 ] - Transformation Service has been started.
21:23:29.391 [DEBUG] [m.internal.MultimediaActivator:34 ] - Multimedia I/O bundle has been started.
21:23:29.763 [DEBUG] [.s.i.DiscoveryServiceActivator:27 ] - Discovery service has been started.
21:23:29.839 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl:93 ] - mDNS service has been started
21:23:30.096 [DEBUG] [.io.transport.mqtt.MqttService:123 ] - Starting MQTT Service...
21:23:30.749 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl:53 ] - Service Discovery initialization completed.
21:23:32.589 [DEBUG] [.i.internal.ItemModelActivator:24 ] - Registered 'item' configuration parser
21:23:34.305 [DEBUG] [o.o.c.i.items.ItemRegistryImpl:137 ] - Item provider 'GenericItemProvider' has been added.
21:23:43.900 [INFO ] [c.internal.ModelRepositoryImpl:80 ] - Loading model 'demo.items'
21:23:48.146 [DEBUG] [i.internal.GenericItemProvider:154 ] - Processing binding configs for items from model 'demo.items'
21:23:48.295 [DEBUG] [i.internal.GenericItemProvider:133 ] - Read items from model 'demo.items'
21:23:49.990 [DEBUG] [.o.m.s.i.SitemapModelActivator:23 ] - Registered 'sitemap' configuration parser
21:23:51.196 [DEBUG] [io.rest.internal.RESTActivator:33 ] - REST API has been started.
21:23:52.034 [INFO ] [org.atmosphere.util.IOUtils :370 ] - META-INF/services/org.atmosphere.cpr.AtmosphereFramework not found in class loader
21:23:52.518 [INFO ] [sphere.cpr.AtmosphereFramework:2601 ] - Atmosphere is using org.atmosphere.cpr.DefaultAnnotationProcessor for processing annotation
21:23:52.535 [INFO ] [cpr.DefaultAnnotationProcessor:138 ] - AnnotationProcessor class org.atmosphere.cpr.DefaultAnnotationProcessor$Byte codeBasedAnnotationProcessor being used
21:23:53.175 [WARN ] [cpr.DefaultAnnotationProcessor:178 ] - Unable to detect annotations. Application may fail to deploy.
21:23:53.561 [INFO ] [sphere.cpr.AtmosphereFramework:1891 ] - Auto detecting atmosphere handlers /WEB-INF/classes/
21:23:53.831 [INFO ] [sphere.cpr.AtmosphereFramework:639 ] - Installed AtmosphereHandler org.atmosphere.handler.ReflectorServletProcessor mapped to context-path /* and Broadcaster Class org.atmosphere.jersey.JerseyBroadcaster
21:23:53.841 [INFO ] [sphere.cpr.AtmosphereFramework:1945 ] - Auto detecting WebSocketHandler in /WEB-INF/classes/
21:23:53.861 [INFO ] [sphere.cpr.AtmosphereFramework:1602 ] - Installed WebSocketProtocol org.atmosphere.websocket.protocol.SimpleHttpProtoc ol
21:23:54.272 [INFO ] [.a.h.ReflectorServletProcessor:103 ] - Installing Servlet com.sun.jersey.spi.container.servlet.ServletContai ner
21:23:56.403 [INFO ] [c.s.j.s.i.a.WebApplicationImpl:815 ] - Initiating Jersey application, version 'Jersey: 1.18.1 02/19/2014 03:28 AM'
21:23:56.434 [INFO ] [c.s.j.s.i.a.WebApplicationImpl:826 ] - Adding the following classes declared in META-INF/services/jersey-server-components to the resource configuration:
class org.atmosphere.jersey.AtmosphereResourceConfigurat or
21:23:57.330 [INFO ] [j.s.i.a.DeferredResourceConfig:101 ] - Instantiated the Application class org.openhab.io.rest.RESTApplication
21:24:01.604 [INFO ] [c.internal.ModelRepositoryImpl:80 ] - Loading model 'demo.sitemap'
21:24:20.048 [INFO ] [sphere.cpr.AtmosphereFramework:2435 ] - AtmosphereInterceptor CORS Interceptor Support will always be executed first
21:24:20.055 [INFO ] [sphere.cpr.AtmosphereFramework:2404 ] - Installed AtmosphereInterceptor CORS Interceptor Support with priority FIRST_BEFORE_DEFAULT
21:24:20.066 [INFO ] [sphere.cpr.AtmosphereFramework:2404 ] - Installed AtmosphereInterceptor Default Response's Headers Interceptor with priority AFTER_DEFAULT
21:24:20.095 [INFO ] [sphere.cpr.AtmosphereFramework:2404 ] - Installed AtmosphereInterceptor Android Interceptor Support with priority AFTER_DEFAULT
21:24:20.113 [INFO ] [sphere.cpr.AtmosphereFramework:2404 ] - Installed AtmosphereInterceptor SSE Interceptor Support with priority AFTER_DEFAULT
21:24:20.124 [INFO ] [sphere.cpr.AtmosphereFramework:2404 ] - Installed AtmosphereInterceptor JSONP Interceptor Support with priority AFTER_DEFAULT
21:24:20.145 [INFO ] [sphere.cpr.AtmosphereFramework:2404 ] - Installed AtmosphereInterceptor Atmosphere JavaScript Protocol with priority AFTER_DEFAULT
21:24:20.156 [INFO ] [sphere.cpr.AtmosphereFramework:2404 ] - Installed AtmosphereInterceptor Browser disconnection detection with priority AFTER_DEFAULT
21:24:20.201 [INFO ] [sphere.cpr.AtmosphereFramework:935 ] - Using EndpointMapper class org.atmosphere.util.DefaultEndpointMapper
21:24:20.218 [WARN ] [sphere.cpr.AtmosphereFramework:941 ] - No BroadcasterCache configured. Broadcasted message between client reconnection will be LOST. It is recommended to configure the org.atmosphere.cache.UUIDBroadcasterCache
21:24:20.225 [INFO ] [sphere.cpr.AtmosphereFramework:949 ] - Default Broadcaster Class: org.atmosphere.jersey.JerseyBroadcaster
21:24:20.233 [INFO ] [sphere.cpr.AtmosphereFramework:950 ] - Broadcaster Polling Wait Time 100
21:24:20.239 [INFO ] [sphere.cpr.AtmosphereFramework:951 ] - Shared ExecutorService supported: true
21:24:20.247 [INFO ] [sphere.cpr.AtmosphereFramework:958 ] - Messaging Thread Pool Size: 10
21:24:20.267 [INFO ] [sphere.cpr.AtmosphereFramework:968 ] - Async I/O Thread Pool Size: 10
21:24:20.274 [INFO ] [sphere.cpr.AtmosphereFramework:979 ] - Using BroadcasterFactory: org.atmosphere.cpr.DefaultBroadcasterFactory
21:24:20.281 [INFO ] [sphere.cpr.AtmosphereFramework:980 ] - Using WebSocketProcessor: org.atmosphere.websocket.DefaultWebSocketProcessor
21:24:20.289 [INFO ] [sphere.cpr.AtmosphereFramework:990 ] - Invoke AtmosphereInterceptor on WebSocket message true
21:24:20.295 [INFO ] [sphere.cpr.AtmosphereFramework:991 ] - HttpSession supported: false
21:24:20.302 [INFO ] [sphere.cpr.AtmosphereFramework:993 ] - Atmosphere is using DefaultAtmosphereObjectFactory for dependency injection and object creation
21:24:20.310 [INFO ] [sphere.cpr.AtmosphereFramework:994 ] - Atmosphere is using async support: org.atmosphere.container.JettyAsyncSupportWithWebS ocket running under container: jetty/8.1.3.v20120522 with WebSocket enabled.
21:24:20.328 [INFO ] [sphere.cpr.AtmosphereFramework:996 ] - Atmosphere Framework 2.2.5 started.
21:24:20.335 [INFO ] [sphere.cpr.AtmosphereFramework:998 ] -
For Atmosphere Framework Commercial Support, visit
http://www.async-io.org/ or send an email to support@async-io.org
21:24:20.356 [INFO ] [penhab.io.rest.RESTApplication:144 ] - Started REST API at /rest
21:24:20.388 [DEBUG] [o.o.i.s.i.DiscoveryServiceImpl:66 ] - Registering new service _openhab-server._tcp.local. at port 8080
21:24:22.951 [DEBUG] [o.o.i.s.i.DiscoveryServiceImpl:66 ] - Registering new service _openhab-server-ssl._tcp.local. at port 8443
21:24:26.553 [INFO ] [.o.u.w.i.servlet.WebAppServlet:80 ] - Started Classic UI at /classicui/openhab.app
21:24:31.497 [DEBUG] [.r.internal.RuleModelActivator:42 ] - Registered 'rules' configuration parser
21:24:31.736 [DEBUG] [m.r.internal.engine.RuleEngine:77 ] - Started rule engine
21:24:37.177 [DEBUG] [a.p.internal.PushoverActivator:35 ] - Pushover action has been started.
21:24:37.224 [DEBUG] [.o.a.p.i.PushoverActionService:90 ] - Pushover action service activated
21:24:37.297 [DEBUG] [.o.a.p.i.PushoverActionService:112 ] - Configuration file is being parsed.
21:24:37.333 [DEBUG] [.o.a.p.i.PushoverActionService:114 ] - Configuration data exists. Parsing the paramaters.
21:24:37.582 [DEBUG] [.b.n.internal.NetatmoActivator:42 ] - Netatmo binding has been started.
21:24:38.756 [INFO ] [c.internal.ModelRepositoryImpl:80 ] - Loading model 'demo.rules'
21:24:42.289 [DEBUG] [m.r.internal.engine.RuleEngine:264 ] - Executing startup rule 'Set Rollershutters at startup'
21:24:45.620 [DEBUG] [riptExtensionClassNameProvider:63 ] - Script actions have changed: PushoverActionService, HTTPActionService, PingActionService, AudioActionService, TransformationActionService, ExecActionService,
21:25:06.306 [DEBUG] [.a.internal.bus.AstroActivator:32 ] - Astro binding has been started.
21:28:37.803 [INFO ] [.service.AbstractActiveService:169 ] - Netatmo Refresh Service has been started
21:28:37.813 [DEBUG] [.o.b.n.internal.NetatmoBinding:110 ] - Querying Netatmo API
21:28:37.825 [DEBUG] [.o.b.n.internal.NetatmoBinding:759 ] - Refreshing access token.
21:28:40.286 [DEBUG] [.o.b.n.internal.NetatmoBinding:763 ] - Request: RefreshTokenRequest[clientId=,clientSecret=,re freshToken= ]
21:28:40.295 [DEBUG] [.o.b.n.i.m.RefreshTokenRequest:86 ] - HTTP Post url='https://api.netatmo.net/oauth2/token' content='grant_type=refresh_token&refresh_token=&c lient_id=&client_se cret=&scope=read_station'
21:28:47.262 [DEBUG] [.o.b.n.internal.NetatmoBinding:766 ] - Response: RefreshTokenResponse[accessToken=]
21:28:47.279 [DEBUG] [b.n.i.m.GetStationsDataRequest:78 ] - HTTP Post url='https://api.netatmo.net/api/getstationsdata' content='access_token='
21:28:49.570 [DEBUG] [.o.b.n.internal.NetatmoBinding:370 ] - Request: GetStationsDataRequest[accessToken=]
21:28:49.668 [DEBUG] [.o.b.n.internal.NetatmoBinding:371 ] - Response: GetStationsDataResponse[status=ok,body=GetStationsDataResponse.Body[devices=[GetStationsDataResponse.Device[id=70:ee:50:00:26:e4,co2Calibrating=false,firmware =124,lastStatusStore=Sun Jan 18 03:00:40 CET 1970,lastUpgrade=Sat Jan 17 16:59:31 CET 1970,moduleName=Indoor Stube,modules=[GetStationsDataResponse.Module[id=02:00:00:00:29:98,moduleName=Outdoor Balkon,type=NAModule1,firmware=44,lastMessage=Sun Jan 18 03:00:40 CET 1970,lastSeen=Sun Jan 18 03:00:40 CET 1970,rfStatus=56,batteryVp=5006,dataTypes=[Temperature, Humidity]], GetStationsDataResponse.Module[id=03:00:00:00:a2:46,moduleName=Indoor Schlafzimmer,type=NAModule4,firmware=44,lastMessag e=Sun Jan 18 03:00:40 CET 1970,lastSeen=Sun Jan 18 03:00:40 CET 1970,rfStatus=74,batteryVp=5181,dataTypes=[Temperature, CO2, Humidity]], GetStationsDataResponse.Module[id=05:00:00:00:f0:1a,moduleName=Regen,type=NAModul e3,firmware=8,lastMessage=Sun Jan 18 03:00:40 CET 1970,lastSeen=Sun Jan 18 03:00:40 CET 1970,rfStatus=67,batteryVp=5232,dataTypes=[Rain]], GetStationsDataResponse.Module[id=06:00:00:00:08:e8,moduleName=Wind,type=NAModule 2,firmware=17,lastMessage=Sun Jan 18 03:00:40 CET 1970,lastSeen=Sun Jan 18 03:00:40 CET 1970,rfStatus=74,batteryVp=5124,dataTypes=[Wind]]],place=GetStationsDataResponse.Place[altitude=551.0,city=Munchenbuchsee,country=CH,impr oveLocProposed=<null>,location=[7.453, 47.02388],timezone=Europe/Zurich],stationName=Niggli_Buchsi,type=NAMain,wifiStatus= 23,measurements=[Temperature, CO2, Humidity, Noise, Pressure]], GetStationsDataResponse.Device[id=70:ee:50:00:14:78,co2Calibrating=false,firmware =124,lastStatusStore=Sun Jan 18 03:00:40 CET 1970,lastUpgrade=Sun Jan 18 01:49:33 CET 1970,moduleName=Indoor base,modules=[GetStationsDataResponse.Module[id=03:00:00:00:02:94,moduleName=Winecellar,type=NA Module4,firmware=44,lastMessage=Sun Jan 18 03:00:40 CET 1970,lastSeen=Sun Jan 18 03:00:40 CET 1970,rfStatus=83,batteryVp=5126,dataTypes=[Temperature, CO2, Humidity]], GetStationsDataResponse.Module[id=03:00:00:00:71:70,moduleName=Wintergarden,type= NAModule4,firmware=44,lastMessage=Sun Jan 18 03:00:40 CET 1970,lastSeen=Sun Jan 18 03:00:40 CET 1970,rfStatus=68,batteryVp=5103,dataTypes=[Temperature, CO2, Humidity]], GetStationsDataResponse.Module[id=03:00:00:00:b6:d0,moduleName=Upstairs,type=NAMo dule4,firmware=44,lastMessage=Sun Jan 18 03:00:40 CET 1970,lastSeen=Sun Jan 18 03:00:40 CET 1970,rfStatus=63,batteryVp=5102,dataTypes=[Temperature, CO2, Humidity]], GetStationsDataResponse.Module[id=05:00:00:02:1e:8a,moduleName=Rain,type=NAModule 3,firmware=8,lastMessage=Sun Jan 18 03:00:40 CET 1970,lastSeen=Sun Jan 18 03:00:40 CET 1970,rfStatus=74,batteryVp=5756,dataTypes=[Rain]], GetStationsDataResponse.Module[id=06:00:00:00:84:16,moduleName=Wind,type=NAModule 2,firmware=17,lastMessage=Sun Jan 18 03:00:40 CET 1970,lastSeen=Sun Jan 18 03:00:40 CET 1970,rfStatus=80,batteryVp=4406,dataTypes=[Wind]], GetStationsDataResponse.Module[id=02:00:00:00:15:74,moduleName=Outdoor,type=NAMod ule1,firmware=44,lastMessage=Sun Jan 18 03:00:40 CET 1970,lastSeen=Sun Jan 18 03:00:40 CET 1970,rfStatus=58,batteryVp=5264,dataTypes=[Temperature, Humidity]]],place=GetStationsDataResponse.Place[altitude=510.0,city=Burgdorf,country=CH,improveLoc Proposed=<null>,location=[7.5394, 47.07031],timezone=Europe/Zurich],stationName=Zauggen,type=NAMain,wifiStatus=54,mea surements=[Temperature, CO2, Humidity, Noise, Pressure]], GetStationsDataResponse.Device[id=70:ee:50:00:2c:d0,co2Calibrating=false,firmware =124,lastStatusStore=Sun Jan 18 03:00:40 CET 1970,lastUpgrade=Sat Jan 17 16:59:31 CET 1970,moduleName=Wohnzimmer,modules=[GetStationsDataResponse.Module[id=03:00:00:00:77:68,moduleName=Kinderzimmer,type= NAModule4,firmware=44,lastMessage=Sun Jan 18 03:00:40 CET 1970,lastSeen=Sun Jan 18 03:00:40 CET 1970,rfStatus=69,batteryVp=5171,dataTypes=[Temperature, CO2, Humidity]], GetStationsDataResponse.Module[id=02:00:00:00:30:58,moduleName=Draussen,type=NAMo dule1,firmware=44,lastMessage=Sun Jan 18 03:00:40 CET 1970,lastSeen=Sun Jan 18 03:00:40 CET 1970,rfStatus=73,batteryVp=5528,dataTypes=[Temperature, Humidity]], GetStationsDataResponse.Module[id=05:00:00:02:8d:54,moduleName=Regenmesser,type=N AModule3,firmware=8,lastMessage=Sun Jan 18 03:00:40 CET 1970,lastSeen=Sun Jan 18 03:00:40 CET 1970,rfStatus=89,batteryVp=5318,dataTypes=[Rain]]],place=GetStationsDataResponse.Place[altitude=497.0,city=Bienne,country=CH,improveLocPr oposed=<null>,location=[7.2467999458313, 47.143001556396],timezone=Europe/Zurich],stationName=Fraubrunnen,type=NAMain,wifiStatus=54 ,measurements=[Temperature, CO2, Humidity, Noise, Pressure]], GetStationsDataResponse.Device[id=70:ee:50:00:50:ee,co2Calibrating=false,firmware =102,lastStatusStore=Sun Jan 18 03:00:41 CET 1970,lastUpgrade=Sat Jan 17 16:59:32 CET 1970,moduleName=Indoor,modules=[GetStationsDataResponse.Module[id=02:00:00:00:46:66,moduleName=Outdoor,type=NAMod ule1,firmware=43,lastMessage=Sun Jan 18 03:00:41 CET 1970,lastSeen=Sun Jan 18 03:00:41 CET 1970,rfStatus=64,batteryVp=4658,dataTypes=[Temperature, Humidity]]],place=GetStationsDataResponse.Place[altitude=45.0,city=Newark,country=US,improveLocPro posed=<null>,location=[-74.187838559034, 40.739941646825],timezone=America/New_York],stationName=Nata_SOrangeNJ,type=NAMain,wifiStatus =49,measurements=[Temperature, CO2, Humidity, Noise, Pressure]]]],executionTime=0.070482015609741]
21:28:49.702 [INFO ] [.o.b.n.internal.NetatmoBinding:493 ] - The following Netatmo measurements are not yet configured:
70:ee:50:00:14:78#Temperature (Indoor base)
70:ee:50:00:14:78#Noise (Indoor base)
70:ee:50:00:14:78#CO2 (Indoor base)
70:ee:50:00:14:78#Humidity (Indoor base)
70:ee:50:00:14:78#Pressure (Indoor base)
70:ee:50:00:26:e4#Temperature (Indoor Stube)
70:ee:50:00:26:e4#Noise (Indoor Stube)
70:ee:50:00:26:e4#CO2 (Indoor Stube)
70:ee:50:00:26:e4#Humidity (Indoor Stube)
70:ee:50:00:26:e4#Pressure (Indoor Stube)
70:ee:50:00:50:ee#Temperature (Indoor)
70:ee:50:00:50:ee#Noise (Indoor)
70:ee:50:00:50:ee#CO2 (Indoor)
70:ee:50:00:50:ee#Humidity (Indoor)
70:ee:50:00:50:ee#Pressure (Indoor)
70:ee:50:00:2c:d0#Temperature (Wohnzimmer)
70:ee:50:00:2c:d0#Noise (Wohnzimmer)
70:ee:50:00:2c:d0#CO2 (Wohnzimmer)
70:ee:50:00:2c:d0#Humidity (Wohnzimmer)
70:ee:50:00:2c:d0#Pressure (Wohnzimmer)
70:ee:50:00:26:e4#06:00:00:00:08:e8#windstrength (Wind)
70:ee:50:00:26:e4#02:00:00:00:29:98#Temperature (Outdoor Balkon)
70:ee:50:00:26:e4#02:00:00:00:29:98#Humidity (Outdoor Balkon)
70:ee:50:00:2c:d0#02:00:00:00:30:58#Temperature (Draussen)
70:ee:50:00:2c:d0#02:00:00:00:30:58#Humidity (Draussen)
70:ee:50:00:14:78#03:00:00:00:b6:d0#Temperature (Upstairs)
70:ee:50:00:14:78#03:00:00:00:b6:d0#CO2 (Upstairs)
70:ee:50:00:14:78#03:00:00:00:b6:d0#Humidity (Upstairs)
70:ee:50:00:26:e4#03:00:00:00:a2:46#Temperature (Indoor Schlafzimmer)
70:ee:50:00:26:e4#03:00:00:00:a2:46#CO2 (Indoor Schlafzimmer)
70:ee:50:00:26:e4#03:00:00:00:a2:46#Humidity (Indoor Schlafzimmer)
70:ee:50:00:14:78#06:00:00:00:84:16#windstrength (Wind)
70:ee:50:00:14:78#02:00:00:00:15:74#Temperature (Outdoor)
70:ee:50:00:14:78#02:00:00:00:15:74#Humidity (Outdoor)
70:ee:50:00:2c:d0#03:00:00:00:77:68#Temperature (Kinderzimmer)
70:ee:50:00:2c:d0#03:00:00:00:77:68#CO2 (Kinderzimmer)
70:ee:50:00:2c:d0#03:00:00:00:77:68#Humidity (Kinderzimmer)
70:ee:50:00:14:78#03:00:00:00:02:94#Temperature (Winecellar)
70:ee:50:00:14:78#03:00:00:00:02:94#CO2 (Winecellar)
70:ee:50:00:14:78#03:00:00:00:02:94#Humidity (Winecellar)
70:ee:50:00:14:78#05:00:00:02:1e:8a#Rain (Rain)
70:ee:50:00:2c:d0#05:00:00:02:8d:54#Rain (Regenmesser)
70:ee:50:00:50:ee#02:00:00:00:46:66#Temperature (Outdoor)
70:ee:50:00:50:ee#02:00:00:00:46:66#Humidity (Outdoor)
70:ee:50:00:26:e4#05:00:00:00:f0:1a#Rain (Regen)
70:ee:50:00:14:78#03:00:00:00:71:70#Temperature (Wintergarden)
70:ee:50:00:14:78#03:00:00:00:71:70#CO2 (Wintergarden)
70:ee:50:00:14:78#03:00:00:00:71:70#Humidity (Wintergarden)
21:29:06.921 [DEBUG] [.o.b.hue.internal.HueActivator:30 ] - Hue binding has been started.
21:30:49.719 [DEBUG] [.o.b.n.internal.NetatmoBinding:110 ] - Querying Netatmo API
21:32:37.844 [INFO ] [.b.a.internal.bus.AstroBinding:70 ] - AstroConfig[latitude=47.016664,longitude=7.450001,interval=600 ,systemTimezone=Europe/Zurich (CET +0200),daylightSavings=true]
21:32:41.180 [INFO ] [.b.a.internal.job.JobScheduler:150 ] - Scheduled a daily job at midnight for astro calculation
21:32:41.406 [DEBUG] [a.internal.job.AbstractBaseJob:40 ] - Starting Astro DailyJob
21:32:41.711 [DEBUG] [.b.a.internal.job.JobScheduler:207 ] - Scheduled job with name Season at 2016-12-21 11:45:00
21:32:41.741 [DEBUG] [.b.astro.internal.job.DailyJob:50 ] - Sun[sunrise=Range[start=Sun Oct 09 07:41:00 CEST 2016,end=Sun Oct 09 07:44:00 CEST 2016],noon=Range[start=Sun Oct 09 13:19:00 CEST 2016,end=Sun Oct 09 13:20:00 CEST 2016],sunset=Range[start=Sun Oct 09 18:53:00 CEST 2016,end=Sun Oct 09 18:56:00 CEST 2016],night=Range[start=Sun Oct 09 20:37:00 CEST 2016,end=Mon Oct 10 06:02:00 CEST 2016],morningNight=Range[start=Sun Oct 09 00:00:00 CEST 2016,end=Sun Oct 09 06:00:00 CEST 2016],astroDawn=Range[start=Sun Oct 09 06:00:00 CEST 2016,end=Sun Oct 09 06:36:00 CEST 2016],nauticDawn=Range[start=Sun Oct 09 06:36:00 CEST 2016,end=Sun Oct 09 07:11:00 CEST 2016],civilDawn=Range[start=Sun Oct 09 07:11:00 CEST 2016,end=Sun Oct 09 07:41:00 CEST 2016],civilDusk=Range[start=Sun Oct 09 18:56:00 CEST 2016,end=Sun Oct 09 19:26:00 CEST 2016],nauticDusk=Range[start=Sun Oct 09 19:26:00 CEST 2016,end=Sun Oct 09 20:01:00 CEST 2016],astroDusk=Range[start=Sun Oct 09 20:01:00 CEST 2016,end=Sun Oct 09 20:37:00 CEST 2016],daylight=Range[start=Sun Oct 09 07:44:00 CEST 2016,end=Sun Oct 09 18:53:00 CEST 2016],eveningNight=Range[start=Sun Oct 09 20:37:00 CEST 2016,end=Mon Oct 10 00:00:00 CEST 2016],eclipse=SunEclipse[total=Mon Aug 21 20:27:00 CEST 2017,partial=Thu Feb 15 21:53:00 CET 2018,ring=Sun Feb 26 15:55:00 CET 2017]]
21:32:41.919 [DEBUG] [.b.astro.internal.job.DailyJob:57 ] - Moon[rise=Sun Oct 09 15:05:00 CEST 2016,set=Mon Oct 10 00:44:00 CEST 2016,phase=MoonPhase[firstQuarter=Sun Oct 09 06:34:00 CEST 2016,full=Sun Oct 16 06:24:00 CEST 2016,thirdQuarter=Sat Oct 22 21:15:00 CEST 2016,new=Sun Oct 30 18:40:00 CET 2016,age=8,illumination=56.256120237015715,name=FI RST_QUARTER],apogee=MoonDistance[date=Mon Oct 31 20:30:00 CET 2016,kilometer=406661.30788094836,miles=252687.621 6182639],perigee=MoonDistance[date=Mon Oct 17 01:36:00 CEST 2016,kilometer=357860.4225355354,miles=222364.1573 205293],distance=MoonDistance[date=Sun Oct 09 21:32:41 CEST 2016,kilometer=390959.22940570896,miles=242930.802 39922684],eclipse=Eclipse[total=Wed Jan 31 14:31:00 CET 2018,partial=Mon Aug 07 20:22:00 CEST 2017],position=Position[azimuth=204.65304328446797,elevation=21.0795627103 098],zodiac=org.openhab.binding.astro.internal.model.Z odiac@d82a2c]
21:32:49.725 [DEBUG] [.o.b.n.internal.NetatmoBinding:110 ] - Querying Netatmo API
21:34:49.733 [DEBUG] [.o.b.n.internal.NetatmoBinding:110 ] - Querying Netatmo API
21:36:49.738 [DEBUG] [.o.b.n.internal.NetatmoBinding:110 ] - Querying Netatmo API
Here the output from two commands which were suggested to me:
pi@raspberrypi:~ $ ps -ef | grep java
pi 1515 1509 12 20:08 pts/0 00:02:48 java -Dosgi.clean=true -Declipse.ignoreApp=true -Dosgi.noShutdown=true -Djetty.port=8080 -Djetty.port.ssl=8443 -Djetty.home=. -Dlogback.configurationFile=configurations/logback.xml -Dfelix.fileinstall.dir=addons -Dfelix.fileinstall.filter=.*\.jar -Djava.library.path=lib -Djava.security.auth.login.config=./etc/login.conf -Dorg.quartz.properties=./etc/quartz.properties -Dequinox.ds.block_timeout=240000 -Dequinox.scr.waitTimeOnBlock=60000 -Dfelix.fileinstall.active.level=4 -Djava.awt.headless=true -jar server/plugins/org.eclipse.equinox.launcher_1.3.0.v20120522-1813.jar -console
pi 2789 1906 1 20:29 pts/1 00:00:00 grep --color=auto java
pi@raspberrypi:~ $ sudo netstat -pan | grep java
tcp6 0 0 :::8443 :::* LISTEN 1515/java
tcp6 0 0 :::8080 :::* LISTEN 1515/java
tcp6 1 0 192.168.1.125:8080 192.168.1.142:49543 CLOSE_WAIT 1515/java
tcp6 1 0 192.168.1.125:8080 192.168.1.142:49485 CLOSE_WAIT 1515/java
tcp6 1 0 192.168.1.125:8080 192.168.1.142:49379 CLOSE_WAIT 1515/java
tcp6 1 0 192.168.1.125:8080 192.168.1.142:49389 CLOSE_WAIT 1515/java
tcp6 0 0 192.168.1.125:8080 192.168.1.142:49551 ESTABLISHED 1515/java
tcp6 1 0 192.168.1.125:8080 192.168.1.142:49487 CLOSE_WAIT 1515/java
udp6 0 0 :::5353 :::* 1515/java
unix 2 [ ] STREAM CONNECTED 9720 1515/java
unix 2 [ ] STREAM CONNECTED 9727 1515/java
