I have been searching to try and figure out this problem and have tried multiple ways of doing it from all my research.
I’m getting this error every time I try and round the calculated distance to 2 decimal places on this example.
Rule 'Justin Distance from home': f != org.eclipse.smarthome.core.library.items.NumberItem
rule "Justin Distance from home"
Item Justin_iPhone_Location changed
Justin_Home_Location.state = new PointType(new DecimalType(00.000000), new DecimalType(-00.000000)) // Change to Yards
Justin_Distance_From_Home.postUpdate((Justin_Home_Location.distanceFrom(Justin_iPhone_Location) * 1.09361))
logInfo("iCloud.rules",String::format("Justin's Distance from home: %.2f", Justin_Distance_From_Home))
I am coming from this rule and trying to shorten the number below…
logInfo("iCloud.rules","Justin's distance from home: "+ Justin_Distance_From_Home.state.toString()+ " Yards")
Justin's Distance from home: 38288.8622330804452828 Yards
I presume you got the problem resolved in your first post. If not, please post the item definition for “Justin_iPhone_Location” . Regarding your second post, see this thread: Round number to #.#. I think it may be a solution for you
val homeLocation = new PointType(new DecimalType(00.000000), new DecimalType(00.000000))
val Number distance = Justin_Home_Location.distanceFrom(Justin_iPhone_Location) * 1.09361
Justin_Distance_From_Home.postUpdate(distance)
logInfo("iCloud.rules","Justin's distance from home: " + String::format("%.1f", distance.floatValue())+ " Yards")
One last Question. I have a JavaScript transform function to change the number of meters to miles, tenth of miles, and feet.
How would i get this one to work? It’s just coming up blank after "Justin’s distance from home: "
logInfo("iCloud.rules", "Justin's distance from home: "+ (transform("JS","PrintTime.js",(Justin_Distance_From_Home.toString))))
What is the best way to learn the proper syntax? Is that Java? What topics would this be considered to try and hone in on to better lean this?
The last one you sent works, you were right about I forgot to put in the “.state” and too many brackets. I think maybe I was jumping the gun and looking at the wrong rule refresh before the previous one got unloaded.
Thanks Guys, always speedy responses and helping the little guys out
