I enabled the AVM Fritz binding and configured some items according the documentation.
But then I checked the logfile, which is full with the same errors.
Any ideas, how to find (and solve) the problem?
AVM FritzBox 7490, latest FritzOS 6.93 firmware, 6 Eurotronic Comet DECT thermostats, 4 DECT 200 and also two Powerline 546e.
“2017-03-23 14:53:15.896 [ERROR] [nding.avmfritz.handler.DeviceHandler] -
java.lang.NullPointerException
at org.openhab.binding.avmfritz.handler.DeviceHandler.addDeviceList(DeviceHandler.java:186)[237:org.openhab.binding.avmfritz:2.0.0]
at org.openhab.binding.avmfritz.internal.hardware.callbacks.FritzAhaUpdateXmlCallback.execute(FritzAhaUpdateXmlCallback.java:70)[237:org.openhab.binding.avmfritz:2.0.0]
at org.openhab.binding.avmfritz.internal.hardware.FritzahaContentExchange.onComplete(FritzahaContentExchange.java:71)[237:org.openhab.binding.avmfritz:2.0.0]
at org.eclipse.jetty.client.ResponseNotifier.notifyComplete(ResponseNotifier.java:193)[69:org.eclipse.jetty.client:9.2.19.v20160908]
at org.eclipse.jetty.client.ResponseNotifier.notifyComplete(ResponseNotifier.java:185)[69:org.eclipse.jetty.client:9.2.19.v20160908]
at org.eclipse.jetty.client.HttpReceiver.terminateResponse(HttpReceiver.java:453)[69:org.eclipse.jetty.client:9.2.19.v20160908]
at org.eclipse.jetty.client.HttpReceiver.responseSuccess(HttpReceiver.java:400)[69:org.eclipse.jetty.client:9.2.19.v20160908]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.messageComplete(HttpReceiverOverHTTP.java:266)[69:org.eclipse.jetty.client:9.2.19.v20160908]
at org.eclipse.jetty.http.HttpParser.parseContent(HttpParser.java:1487)[71:org.eclipse.jetty.http:9.2.19.v20160908]
at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:1245)[71:org.eclipse.jetty.http:9.2.19.v20160908]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.parse(HttpReceiverOverHTTP.java:156)[69:org.eclipse.jetty.client:9.2.19.v20160908]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.process(HttpReceiverOverHTTP.java:117)[69:org.eclipse.jetty.client:9.2.19.v20160908]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.receive(HttpReceiverOverHTTP.java:69)[69:org.eclipse.jetty.client:9.2.19.v20160908]
at org.eclipse.jetty.client.http.HttpChannelOverHTTP.receive(HttpChannelOverHTTP.java:89)[69:org.eclipse.jetty.client:9.2.19.v20160908]
at org.eclipse.jetty.client.http.HttpConnectionOverHTTP.onFillable(HttpConnectionOverHTTP.java:123)[69:org.eclipse.jetty.client:9.2.19.v20160908]
at org.eclipse.jetty.io.AbstractConnection$2.run(AbstractConnection.java:544)[72:org.eclipse.jetty.io:9.2.19.v20160908]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:635)[83:org.eclipse.jetty.util:9.2.19.v20160908]
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:555)[83:org.eclipse.jetty.util:9.2.19.v20160908]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_121]”
