Problems with CENTRAL_SCENE and HS-WD100+ Dimmer Switch
This device was working just fine until recently, now I’m not getting any CENTRAL_SCENE notifications from the device. Is there an issue with the the latest snapshots? I noticed this after turning off simple mode for channel binding and specified my own item.
When I trigger a scene command from the switch nothing shows up in the DEBUG logs. When the wall switch is turned off/on it’s supposed to also send out a CENTRAL_SCENE update. It’s not doing that either, but I do get the following:
2016-10-06 20:26:00.674 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 19 00 49 84 0D 13 04 11 01 5E 86 72 5A 85 59 73 26 27 70 2C 2B 5B 7A EF 5B 9D
2016-10-06 20:26:00.690 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2016-10-06 20:26:00.694 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 19 00 49 84 0D 13 04 11 01 5E 86 72 5A 85 59 73 26 27 70 2C 2B 5B 7A EF 5B 9D
2016-10-06 20:26:00.696 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 19 00 49 84 0D 13 04 11 01 5E 86 72 5A 85 59 73 26 27 70 2C 2B 5B 7A EF 5B 9D
2016-10-06 20:26:00.700 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationUpdate[0x49], type=Request[0x00], priority=High, dest=255, callback=0, payload=84 0D 13 04 11 01 5E 86 72 5A 85 59 73 26 27 70 2C 2B 5B 7A EF 5B
2016-10-06 20:26:00.702 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 13: Application update request. Node information received.
2016-10-06 20:26:00.704 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 13: Starting initialisation from DONE
2016-10-06 20:26:00.706 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@133597e already registered
2016-10-06 20:26:00.708 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Immediate, dest=10, callback=232, payload=0A 02 84 08
2016-10-06 20:26:00.712 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=ApplicationUpdate[0x49], type=Request[0x00], priority=High, dest=255, callback=0, payload=84 0D 13 04 11 01 5E 86 72 5A 85 59 73 26 27 70 2C 2B 5B 7A EF 5B
2016-10-06 20:26:00.713 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationUpdate, callback id=232, expected=SendData, cancelled=false      MISMATCH
If the device isn’t sending notifications, then I don’t think that’s likely to be an issue with the binding. If nothing gets received, then it must be a configuration issue in the device I think - maybe the association got removed or something…
@chris This would be the associate group, right? I checked and it is empty.
I’ve tried to set it, but it doesn’t seem to stick. Using HABmin, I see this in the logs
2016-10-07 12:04:42.650 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 13: Incoming command class ASSOCIATION
2016-10-07 12:04:42.652 [DEBUG] [ndclass.ZWaveAssociationCommandClass] - NODE 13: Received ASSOCIATION command V1
2016-10-07 12:04:42.654 [DEBUG] [ndclass.ZWaveAssociationCommandClass] - NODE 13: association group 1 has max associations 5
2016-10-07 12:04:42.656 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveAssociationEvent
2016-10-07 12:04:42.659 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 13: Got an event from Z-Wave network: ZWaveAssociationEvent
2016-10-07 12:04:42.660 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 13: Got a value event from Z-Wave network, endpoint = 0, command class = ASSOCIATION, value = 0
2016-10-07 12:04:42.662 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 13: Update ASSOCIATION group_1
2016-10-07 12:04:42.663 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 13: Update ASSOCIATION group_1: 0 members
2016-10-07 12:04:42.665 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 13: Config updated
If I try PaperUI, I see
2016-10-07 12:08:32.614 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 13: Configuration update received
2016-10-07 12:08:32.679 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 13: Configuration update group_org.openhab.binding.zwave.internal.protocol.ZWaveAssociationGroup@33a264 to []
2016-10-07 12:08:32.683 [INFO ] [ome.io.rest.core.thing.ThingResource] - Received HTTP PUT request for update config at 'things/zwave:device:2b98d8e9:node13/config' for the unknown thing 'zwave:device:2b98d8e9:node13'.
This isn’t anything from HABmin - is there something earlier than this. I guess so as this is the readback - not the command.[quote=“grizzlyjere, post:3, topic:14938”]
[/quote]
I would expect to see the same thing when you use HABmin. It looks like PaperUI is removing the association - or at least in this log, it’s not setting the association.
I turned on trace logging, cleared the log then did the association from HABmin. Everything that came back is here: Association Command Log - Pastebin.com
Thanks. Looks like a bug somewhere - I’ll try and get a fix tonight (once I work out what’s up, but hopefully it won’t be too hard). It looks like it sets the group, and then deletes it again for some reason…
Great! Thanks for looking into this. Happy to run more tests if needed.
Hopefully this will fix the issue -:
Once the tests have run I’ll start a build so if you update the binding in about an hour, it should hopefully be fixed…
@chris Thanks for the quick fix. It worked to allow the association group to now be set.
However for some reason the CENTRAL_SCENE still isn’t being received. There isn’t anything showing up in even the trace logs which I don’t get.
To see if it was a problem with the switch I ran Open Z-Wave Control panel and it’s showing the CENTRAL_SCENE being received. So I’m not sure what’s going on…
Strange - there’s nothing that should filter this, so as far as I know, if the log doesn’t show it being received, then it’s not being received. Maybe it’s at maximum range or something and sometimes it works, and sometimes not?
