Using Openhab 2.5 on Ubuntu 20 64-bit, runing on RPi 4 with 8GB SD Card
ubuntu@ubuntu:/etc/openhab2/sitemaps$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 20.04 LTS
Release: 20.04
Codename: focal
ubuntu@ubuntu:/etc/openhab2/sitemaps$ java -version
openjdk version “1.8.0_252”
OpenJDK Runtime Environment (Zulu 8.46.0.225-CA-linux_aarch64) (build 1.8.0_252-b225)
OpenJDK 64-Bit Server VM (Zulu 8.46.0.225-CA-linux_aarch64) (build 25.252-b225, mixed mode, Evaluation)
ubuntu@ubuntu:/etc/openhab2/items$ cat default.things
ntp:ntp:local [ hostname=204.123.2.72, refreshInterval=60, refreshNtp=30 ]
ubuntu@ubuntu:/etc/openhab2/sitemaps$ cat lucero.sitemap
sitemap lucero label=“Lucero Way” {
Frame label=“Date and Time” {
Text item=Date icon=“calendar”
Frame label=“Ground Floor” {
Switch item=Living_Room_Lamp icon=“light”
ubuntu@ubuntu:/etc/openhab2/items$ cat default.items
DateTime Date “[%1$tA, %1$tB %1$td, %1$tY — %1$tl:%1$tM %1$tp]” { channel=“ntp:ntp:local:dateTime” }
I cannot get the date and time to show on the sitemap.
Any ideas?
