I’am having some problems with my Fibaro FGRM-222. I have totally 4 Fibaro FGRM-222 and I’am using them with Jarolift TDEP-10/14 motors. One of the four rollershutters is working fine with the default device settings, but the other three don’t do anything. The led indicates green and red when sending commands from openhab, but there is no power on the outputs. Calibrating also does nothing. I’ve also tried several combinations of rollershutters on different motors, but still only one of the Fibaro rollershutters is working, so the motors cannot be the problem. I’ve also tried different settings on parameter 18 (Motor operation detection) but nothing worked. (10 is the setting that work on the one rollershutter)
Here is my binding configuration:
Rollershutter RS_ZWAVE_Bedroom_Right "Rolladen Schlafzimmer Rechts" <rollershutter> (G_ZWAVE_Rollershutter_Bedroom) { zwave="7:command=switch_multilevel,invert_state=false,invert_percent=true" }
Number NUM_ZWAVE_Bedroom_Right_Power "Rolladen Schlafzimmer Rechts Stromverbrauch [%.1f W]" <energy> (G_ZWAVE_Rollershutter_Bedroom) { zwave="7:command=sensor_multilevel" }
Number NUM_ZWAVE_Bedroom_Right_Energy "Rolladen Schlafzimmer Rechts Gesamtverbrauch [%.2f KWh]" <energy> (G_ZWAVE_Rollershutter_Bedroom) { zwave="7:command=meter" }
Rollershutter RS_ZWAVE_Bedroom_Left "Rolladen Schlafzimmer links" <rollershutter> (G_ZWAVE_Rollershutter_Bedroom) { zwave="8:command=switch_multilevel,invert_state=false,invert_percent=true" }
Number NUM_ZWAVE_Bedroom_Left_Power "Rolladen Schlafzimmer links Stromverbrauch [%.1f W]" <energy> (G_ZWAVE_Rollershutter_Bedroom) { zwave="8:command=sensor_multilevel" }
Number NUM_ZWAVE_Bedroom_Left_Energy "Rolladen Schlafzimmer links Gesamtverbrauch [%.2f KWh]" <energy> (G_ZWAVE_Rollershutter_Bedroom) { zwave="8:command=meter" }
This is the xml node config that isn’t working:
node7.xml (10.7 KB)
And this is the one that is working:
node8.xml (10.6 KB)
I found one difference in the node configs:
<int>44</int>
<configurationParameter>
<index>44</index>
<size>1</size>
<value>1</value>
<readOnly>false</readOnly>
<writeOnly>false</writeOnly>
</configurationParameter>
</entry>
This value is 0 on the device that is working an 1 on the device that isn’t working, but this configuration parameter isn’t documented in the manual. Could this be the problem?
Edit: I found out that the parameter 44 is the “Self-measurement” parameter to report the power the device itself is using, so this could also not be the problem.
