Than I try:
.# apt-get update --fix-missing => … … E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/dists/stretch/main/binary-armhf/Packages.xz Hash Sum mismatch
_ Hashes of expected file:_
_ - Filesize:11661232 [weak]_
_ - SHA256:872a0594cfde88dc2e9faff85142b819075783235b852e5fce4481b9541a9c18_
_ - SHA1:6c9ac423582e01630483db440578b433e37518a5 [weak]_
_ - MD5Sum:9c0be47387d39c24c9c6a81cacd3a116 [weak]_
_ Hashes of received file:_
_ - SHA256:7ae8a5e53a91930c80e263108c75ee0126dbd71607b73da572923bd0004e38f1_
_ - SHA1:fb771279d6f7296b058b42fb6dbf32292ba90727 [weak]_
_ - MD5Sum:10f5e14ba57ce3ddb715f84407cb9ca8 [weak]_
_ Last modification reported: Fri, 18 Jan 2019 04:35:39 +0000_
_ Release file created at: Fri, 18 Jan 2019 04:38:22 +0000_ E: Some index files failed to download. They have been ignored, or old ones used instead.
Has anyone an idea how to solve these problems my installation seems to have?
The Raspberry is connected with WLAn to my router, can this cause a problem (maybe bad/slow connection; but regulary it works)
The error is saying that the hash doesn’t match the file meaning that someone modified the file without updating the hash which proves that the file you downloaded is actually the file it claims to be.
Reading package lists... Done
- SHA256:eac3ad8f84a5da811f2f334c0373977f4df0de7d516bd104da5f1825dc690e15
- SHA1:5035ffc7a7dc15f667410b996290d0b06eeaf235 [weak]
- MD5Sum:f53d60afb4723e4791e55fcbe2be4c16 [weak]
Last modification reported: Sat, 19 Jan 2019 04:33:50 +0000
Release file created at: Sat, 19 Jan 2019 04:35:59 +0000
That’s nothing to do with you.
That’s the raspberry fundation’s fault. You’ll have to wait until they fixed it. Or you can ask them directly. This has nothing to do with openHAB.
The root problem was that the ftp copy from the grafana package file was corrupted (size was correct), but the hash was bad. First I find to update the packages (apt update), and this went wrong.
So I had two different problems:
raspberry fundation fault
corrupted grafana package file
Now I copy the grafana package file with winscp from my PC to the Raspi and check the hash, now the hash is fine and the install was running well!
