I’ve just received my Aeon Micro Smart Switch 2nd Edition (MSS2E) and I’m trying to configure it to receive the power in watt, but for some reason I only get the power in amps. Here is my item configuration:
Switch SW_ZWAVE_Living_Heating { zwave="18:command=switch_binary,respond_to_basic=true", autoupdate="false" }
Number NUM_ZWAVE_Living_Heating_Power { zwave="18:command=meter,meter_scale=E_W,refresh_interval=60" }
Number NUM_ZWAVE_Living_Heating_Energy { zwave="18:command=meter,meter_scale=E_KWh,refresh_interval=60" }
Number NUM_ZWAVE_Living_Heating_Amps { zwave="18:command=meter,meter_scale=E_A,refresh_interval=60" }
The value NUM_ZWAVE_Living_Heating_Amps is e.g. at 0.039 amps, but the NUM_ZWAVE_Living_Heating_Power is always zero. The E_KWh is also always zero. I’ve already set the “Target for automatic reports” and the “Target for automatic meter reports” to my Z-Stick. Why are only the amps reported?
Hmmm, I don’t have this device but while searching around I only find the config you are already using and it works at other places … sorry, no idea whats wrong.
Edit: I’ve also enabled the trace log. Here is the payload of the watt meter report:
00 12 08 32 02 21 74 00 00 00 00
And this is the payload for the amps meter report:
00 12 08 32 02 A1 6C 00 00 00 1B
Seams as there is no value sent for the watt report, right?
Meter report is “0 watts”. Either there’s nothing plugged into it, it’s defective, or you have a really low wattage device plugged into it. (Plug in a hair dryer and run it to test!)
I’ve connected my oil stove to the switch. There is a big Fan inside the stove that should need at least 20 watts and the fan is powered by the zwave switch. Is this maybe a hardware problem with the zwave switch?
