Problems with nanoCUL and Homegear
Hello All,
I’m havig difficulties to pair a MAX! thermostate to Homegear via a nanoCUL…
The CUL seems to be ok.
homematicbidcos.conf looks like this:
centralAddress = 0xFD21FB
[CUL]
id = traxCUL868
default = true
deviceType = cul
device = /dev/ttyUSB0
responseDelay = 40
minicom gives me the following information:
V
V 1.67 nanoCUL868
C99
72E2E0DE9CAFF0C
45000006002165A
C8930322F8340733
18166C43401876B
F85610AC2B181141
00597FE81350B00
When i start the pairing mode on the thermostate minicom gives me this output:
Z1700040019E029000000001001A04F45513136383837393614
A1776D8E0C5159505DCDCDCCCED7D336E701C3B2A2C232AEE21
776D8E0C5159505DCDCDCCCED7D336E701C3B2A2C232AEE22
1776D8E0C5159505DCDCDCCCED7D336E701C3B2A2C232AEE23
homgear.log says this:
01/22/19 12:08:44.965 Module HomeMatic BidCoS: Info: Pairing mode enabled.
01/22/19 12:08:44.976 RPC Server (Port 2001): Info: Client number 73 is calling RPC method: getInstallMode (2) Parameters:
01/22/19 12:08:44.985 RPC Server (Port 2001): Info: Client number 73 is calling RPC method: listDevices (2) Parameters:
01/22/19 12:08:44.989 RPC Server (Port 2001): Info: Client number 73 is calling RPC method: getDeviceInfo (2) Parameters:
01/22/19 12:08:44.992 RPC Server (Port 2001): Info: Client number 73 is calling RPC method: getAllSystemVariables (2) Parameters:
01/22/19 12:08:44.995 RPC Server (Port 2001): Info: Client number 73 is calling RPC method: getAllScripts (2) Parameters:
01/22/19 12:08:51.211 RPC Server (Port 2001): Info: Client number 73 is calling RPC method: ping (2) Parameters:
(String) 062e9544
01/22/19 12:08:51.245 RPC Server (Port 2001): Info: Client number 73 is calling RPC method: listBidcosInterfaces (2) Parameters:
01/22/19 12:09:06.249 RPC Server (Port 2001): Info: Client number 73 is calling RPC method: ping (2) Parameters:
(String) 062e9544
01/22/19 12:09:06.253 RPC Server (Port 2001): Info: Client number 73 is calling RPC method: listBidcosInterfaces (2) Parameters:
01/22/19 12:09:21.257 RPC Server (Port 2001): Info: Client number 73 is calling RPC method: ping (2) Parameters:
(String) 062e9544
01/22/19 12:09:21.261 RPC Server (Port 2001): Info: Client number 73 is calling RPC method: listBidcosInterfaces (2) Parameters:
01/22/19 12:09:36.268 RPC Server (Port 2001): Info: Client number 73 is calling RPC method: ping (2) Parameters:
(String) 062e9544
01/22/19 12:09:36.272 RPC Server (Port 2001): Info: Client number 73 is calling RPC method: listBidcosInterfaces (2) Parameters:
01/22/19 12:09:44.948 RPC Server (Port 2001): Info: Client number 73 is calling RPC method: setInstallMode (2) Parameters:
(Boolean) 0
(Integer) 60
(Integer) 1
01/22/19 12:09:44.994 Module HomeMatic BidCoS: Info: Pairing mode disabled.
01/22/19 12:09:51.275 RPC Server (Port 2001): Info: Client number 73 is calling RPC method: ping (2) Parameters:
(String) 062e9544
01/22/19 12:09:51.279 RPC Server (Port 2001): Info: Client number 73 is calling RPC method: listBidcosInterfaces (2) Parameters:
01/22/19 12:10:06.284 RPC Server (Port 2001): Info: Client number 73 is calling RPC method: ping (2) Parameters:
(String) 062e9544
01/22/19 12:10:06.288 RPC Server (Port 2001): Info: Client number 73 is calling RPC method: listBidcosInterfaces (2) Parameters:
01/22/19 12:10:21.292 RPC Server (Port 2001): Info: Client number 73 is calling RPC method: ping (2) Parameters:
(String) 062e9544
01/22/19 12:10:21.295 RPC Server (Port 2001): Info: Client number 73 is calling RPC method: listBidcosInterfaces (2) Parameters:
01/22/19 12:10:36.300 RPC Server (Port 2001): Info: Client number 73 is calling RPC method: ping (2) Parameters:
(String) 062e9544
01/22/19 12:10:36.303 RPC Server (Port 2001): Info: Client number 73 is calling RPC method: listBidcosInterfaces (2) Parameters:
01/22/19 12:10:51.307 RPC Server (Port 2001): Info: Client number 73 is calling RPC method: ping (2) Parameters:
(String) 062e9544
01/22/19 12:10:51.311 RPC Server (Port 2001): Info: Client number 73 is calling RPC method: listBidcosInterfaces (2) Parameters:
01/22/19 12:11:05.101 RPC Server (Port 2001): Info: Client number 73 is calling RPC method: setInstallMode (2) Parameters:
(Boolean) 1
(Integer) 60
(Integer) 1
01/22/19 12:11:05.101 Module HomeMatic BidCoS: Info: Pairing mode enabled.
01/22/19 12:11:06.319 RPC Server (Port 2001): Info: Connection from ::ffff:192.168.31.5:36850 accepted. Client number: 137
01/22/19 12:11:06.320 RPC Server (Port 2001): Info: RPC server client id for client number 137 is: 6
01/22/19 12:11:06.321 RPC Server (Port 2001): Info: Client number 137 is calling RPC method: ping (2) Parameters:
(String) 062e9544
01/22/19 12:11:06.324 RPC Server (Port 2001): Info: Client number 137 is calling RPC method: listBidcosInterfaces (2) Parameters:
01/22/19 12:11:21.328 RPC Server (Port 2001): Info: Client number 137 is calling RPC method: ping (2) Parameters:
(String) 062e9544
01/22/19 12:11:21.332 RPC Server (Port 2001): Info: Client number 137 is calling RPC method: listBidcosInterfaces (2) Parameters:
01/22/19 12:11:36.340 RPC Server (Port 2001): Info: Client number 137 is calling RPC method: ping (2) Parameters:
(String) 062e9544
01/22/19 12:11:36.343 RPC Server (Port 2001): Info: Client number 137 is calling RPC method: listBidcosInterfaces (2) Parameters:
01/22/19 12:11:46.796 IPC Server: Info: Connection to IPC server’s client number 126 closed.
01/22/19 12:11:51.347 RPC Server (Port 2001): Info: Client number 137 is calling RPC method: ping (2) Parameters:
(String) 062e9544
01/22/19 12:11:51.350 RPC Server (Port 2001): Info: Client number 137 is calling RPC method: listBidcosInterfaces (2) Parameters:
01/22/19 12:11:59.915 IPC Server: Info: IPC client 2 removed.
01/22/19 12:12:05.121 Module HomeMatic BidCoS: Info: Pairing mode disabled.
01/22/19 12:12:06.354 RPC Server (Port 2001): Info: Client number 137 is calling RPC method: ping (2) Parameters:
(String) 062e9544
01/22/19 12:12:06.358 RPC Server (Port 2001): Info: Client number 137 is calling RPC method: listBidcosInterfaces (2) Parameters:
01/22/19 12:12:21.363 RPC Server (Port 2001): Info: Client number 137 is calling RPC method: ping (2) Parameters:
(String) 062e9544
01/22/19 12:12:21.368 RPC Server (Port 2001): Info: Client number 137 is calling RPC method: listBidcosInterfaces (2) Parameters:
01/22/19 12:12:36.372 RPC Server (Port 2001): Info: Client number 137 is calling RPC method: ping (2) Parameters:
(String) 062e9544
01/22/19 12:12:36.376 RPC Server (Port 2001): Info: Client number 137 is calling RPC method: listBidcosInterfaces (2) Parameters:
01/22/19 12:12:51.381 RPC Server (Port 2001): Info: Client number 137 is calling RPC method: ping (2) Parameters:
(String) 062e9544
01/22/19 12:12:51.384 RPC Server (Port 2001): Info: Client number 137 is calling RPC method: listBidcosInterfaces (2) Parameters:
01/22/19 12:13:06.388 RPC Server (Port 2001): Info: Client number 137 is calling RPC method: ping (2) Parameters:
(String) 062e9544
01/22/19 12:13:06.392 RPC Server (Port 2001): Info: Client number 137 is calling RPC method: listBidcosInterfaces (2) Parameters:
01/22/19 12:13:15.111 IPC Server: Info: Connection accepted. Client number: 147
01/22/19 12:13:15.112 IPC Server: Info: Client 3 successfully registered RPC method “cliOutput” (this method is registered by 1 client(s)).
01/22/19 12:13:15.113 IPC Server: Info: Client 3 successfully registered RPC method “cliOutput-3” (this method is registered by 1 client(s)).
01/22/19 12:13:21.396 RPC Server (Port 2001): Info: Client number 137 is calling RPC method: ping (2) Parameters:
(String) 062e9544
01/22/19 12:13:21.400 RPC Server (Port 2001): Info: Client number 137 is calling RPC method: listBidcosInterfaces (2) Parameters:
01/22/19 12:13:36.125 IPC Server: Info: Connection to IPC server’s client number 147 closed.
01/22/19 12:13:36.404 RPC Server (Port 2001): Info: Client number 137 is calling RPC method: ping (2) Parameters:
(String) 062e9544
01/22/19 12:13:36.407 RPC Server (Port 2001): Info: Client number 137 is calling RPC method: listBidcosInterfaces (2) Parameters:
01/22/19 12:13:37.859 IPC Server: Info: Connection accepted. Client number: 150
01/22/19 12:13:37.860 IPC Server: Info: Client 4 successfully registered RPC method “cliOutput” (this method is registered by 1 client(s)).
01/22/19 12:13:37.861 IPC Server: Info: Client 4 successfully registered RPC method “cliOutput-4” (this method is registered by 1 client(s)).
01/22/19 12:13:40.172 IPC Server: Info: Connection to IPC server’s client number 150 closed.
Any help is appreciated.
Thanks in Advance
Florian
Ho Florian,
please head over to the homegear forum. This is a specific question that has nothing to do with openHAB.
i am sure sathya or pmeyer will help you
Thomas
