I have mosquitto running on a Synology Diskstation (medienkiste). Using e.g. MQTT.fx, I can subscribe to the topic “openhab/” and see state changes of all items being reported. So far so good…
But in habmin, when trying to have a look at persisted data, all i get is an error msg: “error getting list of items supported by the persistence service”. And indeed, looking up persisted items in REST API, i get “Persistence service not queryable: null”. MQTT is set as default persistence service in habmin.
I assume that you installed MQTT persistence. Have you created a persistence file? I use MQTT, but log data to standard rrd4j and also to mysql. your mqtt.persist should contain something like:
// persistence strategies have a name and a definition and are referred to in the “Items” section
Strategies {
Strategies {
everyMinute : "0 * * * * ?"
default = everyChange
Items {
// persist all items every minute and on every change
* : strategy = everyChange, everyMinute
For testing I set it to everyMinute and this seems to work, since I can subscribe to an mqtt topic and see updates every minute. Only problem is getting access to the mosquitto-db to plot some persistence data. I chose to persist using mqtt becausse it seemed like an easy way to store data externally (my pi got entirely frozen once because the rrd4j-db became too big and i wasn’t able to restrict its size).
