Looking for some ideas on how to get this working. I have a USB to RS485 adapter plugged into my Raspberry Pi, running the latest version of Openhab2. It is working fine - I can run
od -x < /dev/ttyUSB1
and i see the correct binary output flowing from the device. I have added the Pentair binding and I see a Serial Bridge thing, which I have configured to use /dev/ttyUSB1. It remains in UNINITIALIZED status. I have tried to remove it so that I can add it again, and the remove just hangs. I have Force Removed it and re-added the Serial Bridge thing, but it still sits in UNINITIALIZED status.
Looking at the log after I add the Thing I see:
2018-12-30 11:48:21.470 [WARN ] [ore.thing.internal.ThingRegistryImpl] - Cannot create thing. No binding found that supports creating a thing of type āpentair:pentair_serial_bridgeā.
2018-12-30 11:48:44.539 [ERROR] [ersey.server.ServerRuntime$Responder] - An I/O error has occurred while writing a response message entity to the container output stream.
org.glassfish.jersey.server.internal.process.MappableException: org.eclipse.jetty.io.EofException
at org.glassfish.jersey.server.internal.MappableExceptionWrapperInterceptor.aroundWriteTo(MappableExceptionWrapperInterceptor.java:92) ~[?:?]
at org.glassfish.jersey.message.internal.WriterInterceptorExecutor.proceed(WriterInterceptorExecutor.java:162) ~[171:org.glassfish.jersey.core.jersey-common:2.22.2]
No, however the openhab2 install seems to do this anyway, my zwave connectivity on /dev/ttyUSB0 works fine and the output of groups openhab shows membership of tty.
thanks. I managed to get -Dgnu.io.rxtx.SerialPorts=/dev/ttyUSB0:/dev/ttyUSB1 working. zwave showed up, but the pentair binding is still uninitialized, whatever that means. And I still get this error in the log
2018-12-30 13:50:00.015 [WARN ] [ore.thing.internal.ThingRegistryImpl] - Cannot create thing. No binding found that supports creating a thing of type āpentair:pentair_serial_bridgeā.
Using Windows, but I have roughly the same issue with the pentair binding. I can run the node.js pool-controller binding against this exact setup, and I get all of the info, can control lights, pump, etc. I am running 2.4.0 version of OpenHAB. Is anyone successfully using this binding? I have tried configuring through paper as well as via manual things configuration.
I have a Pi that is running the node.js code and it works fine. I just wanted to put everything under the openhab umbrella. However, not only does this binding not work, if you read the notes carefully it seems to be readonly, so itās pretty useless even if it did work. Iām going to stick with the node.js code instead.
Well, I think I found one problem with the serial binding⦠PaperUI configures it as pentair:pentair_serial_binding, whereas the documentation has it as just pentair:serial_binding. I have tried running it with the IP binding, using comsocketbridge (windows equivalent to ser2sock), and I donāt get any errors about initializing, but I also donāt get any useful information. Anthony, have you tried using the IP binding with ser2sock running locally?
I have not tried that, seems like too much work when I have the cable from the controller right by the openhab Pi. When Iām back at my house, I can try renaming the serial binding and see if that works. Will be a week or so.
ok, so a year has passed and Iāve now got back to looking at this!
I upgraded to 2.5.0, but I donāt think that was necessary. I had finally got around to using configuration files vs. PaperUI, so I created a pool.things file:
I had to add /dev/ttyUSB1 to EXTRA_JAVA_OPTS and also chown /dev/ttyUSB1 to root:dialout and chmod it to 666. Then this started working.
I was able to get the binding to display information about the pool, but not control it. Maybe this is because this binding is for the Pentair Easytouch and I have a Pentair Intellitouch controller.
Oh well, at least I can still use nodejs PoolController!
Iām also interested in getting this up and running as a binding. I installed a TCP bridge, I can see output via netcat, and my bridge thing is online as green and so is my controller.
However, I get no numbers, and when I send a command to a switch, it doesnāt do anything.
Also, I have the RBG lights if a dump of that communication would be useful.
I have this up and running, and itās working very well.
The developer, Jeff, has a more up-to-date version that I needed in order to get it working. Thatās version 2.5.7.
Itās important to note that Jeff is just some volunteer whoās writing this for free. He has some pool controller setup, but he doesnāt have EVERY pool controller setup. That means that the community needs to help him out by sending him some logs and reports when it doesnāt work. That way, he can update the binding and make it better.
Connected to the bridge using nc IP.OF.My.Bridge 10000 | xxd
Noticed no āFFa5ā in the output, so I switched the serial lines on the bridge. For this particular controller A is Data + and B is Data -
Uninstalled the official OpenHAB binding, and copied the new jar from Jeff into my addons folder.
Things appeared in my inbox and I added them.
My EasyTouch Controller, Intelliflo, and Intellichlor were all found. The easytouch is 90% good, but it doesnāt read Feature Circuits yet. However it can control them. The Pump and Intellichlor are like 50% complete in their parsing and control.
The biggie though- I can control my spa, turn the lights on and off, turn the jets on and off, control the waterfall, see the temperaturesā¦all through openhab. Thatās like 99% of my use case. The rest is likeā¦ok, let me setup an email so I know when my pool needs more salt. Thatās some gravy right there, and itās close, Jeff just needs more support in people sending him logs and bug reports to work out all the kinks.
What I canāt do yet is run a cleaning cycle from OpenHab or check my Intellichlor aside from my current salt concentration. Iām sure thatās coming though. Jeff doesnāt have all these components, so heās somewhat swinging in the dark with regards to parsing them. Iām actually surprised as much parses correctly as does without him having an actual device.
Is the new version installable via OpenHab? I can try it next time Iām in Florida. I have a USB RS485 connector that currently plugs into my RPi running the node-js poolcontroller.
