Hi
I have a Aeon Z-Stick Gen5 and a MultiSensor 6 and I wanted to use it with my openHAB on Debian. Using ozwcp everything works fine, I see both devices, get the correct the values, etc.
But openHAB doesn’t work. My openhab.cfg is:
zwave:port = /dev/ttyACM0
zwave:healtime = 2
zwave:setSUC = true
zwave:masterController = true
The zwave.log says:
2016-05-21 18:27:26.427 [DEBUG] [.zwave.internal.ZWaveActivator:36 ]-Z-Wave binding started. Version 1.8.2
2016-05-21 18:27:26.437 [TRACE] [.i.ZWaveGenericBindingProvider:48 ]-validateItemType(sensor_1_temp, 2:1:command=sensor_multilevel,sensor_type=1)
2016-05-21 18:27:26.437 [TRACE] [.i.ZWaveGenericBindingProvider:57 ]-processBindingConfiguration(sensor_1_temp, 2:1:command=sensor_multilevel,sensor_type=1)
2016-05-21 18:27:26.447 [TRACE] [.i.ZWaveGenericBindingProvider:48 ]-validateItemType(sensor_1_humidity, 2:1:command=sensor_multilevel,sensor_type=5)
2016-05-21 18:27:26.447 [TRACE] [.i.ZWaveGenericBindingProvider:57 ]-processBindingConfiguration(sensor_1_humidity, 2:1:command=sensor_multilevel,sensor_type=5)
2016-05-21 18:27:26.447 [TRACE] [.i.ZWaveGenericBindingProvider:48 ]-validateItemType(sensor_1_luminance, 2:1:command=sensor_multilevel,sensor_type=3)
2016-05-21 18:27:26.448 [TRACE] [.i.ZWaveGenericBindingProvider:57 ]-processBindingConfiguration(sensor_1_luminance, 2:1:command=sensor_multilevel,sensor_type=3)
2016-05-21 18:27:26.448 [TRACE] [.i.ZWaveGenericBindingProvider:48 ]-validateItemType(sensor_1_motion, 2:1:command=sensor_binary,respond_to_basic=true)
2016-05-21 18:27:26.448 [TRACE] [.i.ZWaveGenericBindingProvider:57 ]-processBindingConfiguration(sensor_1_motion, 2:1:command=sensor_binary,respond_to_basic=true)
2016-05-21 18:27:26.449 [TRACE] [.i.ZWaveGenericBindingProvider:48 ]-validateItemType(sensor_1_battery, 2:command=battery)
2016-05-21 18:27:26.449 [TRACE] [.i.ZWaveGenericBindingProvider:57 ]-processBindingConfiguration(sensor_1_battery, 2:command=battery)
2016-05-21 18:27:26.451 [TRACE] [.z.internal.ZWaveActiveBinding:157 ]-allBindingsChanged
2016-05-21 18:27:26.451 [DEBUG] [.z.internal.ZWaveActiveBinding:175 ]-ConverterHandler not initialised. Polling disabled.
2016-05-21 18:27:26.461 [INFO ] [.z.internal.ZWaveActiveBinding:325 ]-Update config, port = /dev/ttyACM0
2016-05-21 18:27:26.461 [INFO ] [.z.internal.ZWaveActiveBinding:330 ]-Update config, healtime = 2
2016-05-21 18:27:26.461 [INFO ] [.z.internal.ZWaveActiveBinding:375 ]-Update config, setSUC = true
2016-05-21 18:27:26.461 [INFO ] [.z.internal.ZWaveActiveBinding:393 ]-Update config, masterController = true
2016-05-21 18:27:26.461 [DEBUG] [.z.internal.ZWaveActiveBinding:282 ]-Initialising zwave binding
Within the openhab.cfg I have only one line:
18:27:26.482 [INFO ] [.service.AbstractActiveService:169 ] - ZWave Refresh Service has been started
The version of the zwave binding is 1.8.2.
In the Habmin menu I don’t see any devices, when I click e.g. on “Heal” I get “Error sending action to server”. I added some example items:
Number sensor_1_temp “Temperature [%.1f °F]” (Motion,Temps) {zwave=“2:1:command=sensor_multilevel,sensor_type=1”}
Number sensor_1_humidity “Humidity [%.0f %%]” (Motion) {zwave=“2:1:command=sensor_multilevel,sensor_type=5”}
Number sensor_1_luminance “Luminance [%.0f Lux]” (Motion) {zwave=“2:1:command=sensor_multilevel,sensor_type=3”}
Contact sensor_1_motion “sensor [MAP(motion.map):%s]” (Motion) {zwave=“2:1:command=sensor_binary,respond_to_basic=true”}
Number sensor_1_battery “Battery [%s %%]” (Motion) {zwave=“2:command=battery”}
But I don’t get any values.
Any ideas? Many thanks in advance.
Best regards
Michael
