Searching for “text files” brings up zillions of hits about configuration, so if this has been discussed before it’s not easy to find.
I’d like to produce simple text file output. My OpenHAB instance is not exposed to the internet, nor do I want it to be. So what I’d like to do is produce a simple text or HTML file that I can manually push to an internet site, which will let me see some basic status information.
I know I can generate this using the REST API, but that’s a pull instead of a push, so I’m curious if this can be done within OpenHAB. Maybe someone has created a text UI, or some other add-on that I am not seeing, or there’s some other way to accomplish it that I haven’t learned yet.
Suggestions?
