Ahh, OK, now I understand what you mentioned in the other topic.
I changed it for the Amazon Dash Button.
Thanks a lot.
In case of non useing the profile (e.g. some of my rules are too complex!) , do I have to change such complex rules from:
Channel "amazondashbutton:dashbutton:fc-a6-67-0c-aa-c7:press" triggered
to
Channel "amazondashbutton:dashbutton:fc-a6-67-0c-aa-c7:press" triggered PRESSED
No, a rule like in your example - without “PRESSED” - will work in the same way.
OK, thanks!
I’ve installed 2.5.0.201901020757 AmazonDashButton Binding.
Nothing happens when I press a Dash Button.
here is my .item
Switch Hue_Light3_Toggle "Licht Bibliothek An/Aus" <light> (GF_Biblio, Lights) [ "Lighting" ] {channel="hue:0100:0017xxxxxxxxxx:8:brightness", channel="amazondashbutton:dashbutton:50-f5-da-xx-xx-xx:press" [profile="rawbutton-toggle-switch"] }
In PaperUI there is also no profile to select in pull-down-menu:
Could be that it was merged after 7:57 h on 02. January 2019?
Yes, I am pretty sure it was later. After lunch.
Ok. Thanks. I’ll wait for next build. #1487
Build is running at the moment…
https://ci.openhab.org/job/PR-openHAB2-Addons/11843/
It is change No. 41
Haha, … then you will have the chance to test it again tonight …
Ok, I’m on #1487 (=2.5.0.201901040921 │ AmazonDashButton Binding)
I could test the profile now: (item see here)
19:10:26.405 [INFO ] [smarthome.event.ChannelTriggeredEvent] - amazondashbutton: dashbutton:50-f5-da-xx-xx-xx:press triggered PRESSED
19:10:26.409 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Hue_Light3_ Toggle' received command ON
First impression: it is running well.
Btw, all my Dashbuttons now trigger the following event:
19:10:26.405 [INFO ] [smarthome.event.ChannelTriggeredEvent] - amazondashbutton: dashbutton:xx-xx-xx-xx-xx-xx:press triggered PRESSED
Both rules are running (new and old):
rule "My Dash Button pressed"
OK. This will reduce my lines in the .rules file! Thanks a lot!
Great. Nice to hear . To reduce code and effort for the user is the idea behind profiles.
Btw, since I use profile I always get a WARNING at OH startup:
2019-01-20 17:17:56.167 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add "Metadata" with key "channel:Hue_Light2_Toggle". It exists already from provider "GenericMetadataProvider"! Failed to add a second with the same UID from provider "GenericMetadataProvider"!
2019-01-20 17:17:56.167 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add "Metadata" with key "channel:Hue_Light3_Toggle". It exists already from provider "GenericMetadataProvider"! Failed to add a second with the same UID from provider "GenericMetadataProvider"!
here are my .items:
Switch Hue_Light2_Toggle "Licht Windfang An/Aus" <light> (GF_Corridor, Lights) [ "Lighting" ] {channel="hue:0100:0017xxxxxxxxx:2:brightness", channel="amazondashbutton:dashbutton:18-74-2e-xx-xx-xx:press" [profile="rawbutton-toggle-switch"] }
Switch Hue_Light3_Toggle "Licht Bibliothek An/Aus" <light> (GF_Biblio, Lights) [ "Lighting" ] {channel="hue:0100:0017xxxxxxxxx:8:brightness", channel="amazondashbutton:dashbutton:50-f5-da-xx-xx-xx:press" [profile="rawbutton-toggle-switch"] }
It seems to appear ONLY with Hue items:
See also here:
Hi Alex,
It is already known and definitely not related to the Hue binding. I seeing it in my environment for any item using a profile and others too.
That is not true for my environment. I have e.g. http1 binding. 7 items with http channel. There I use profile with Amazon Dash Buttons. No warnings.
I believe this issue is related to be using the additional channel definition in the same item…
I have this issue each time I start openhab 2.5M1 build #1575
2019-03-19 18:52:50.458 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add "Metadata" with key "channel:stort_badDimmerLys". It exists already from provider "GenericMetadataProvider"! Failed to add a second with the same UID from provider "GenericMetadataProvider"!
2019-03-19 18:52:50.471 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add "Metadata" with key "channel:sove_lampeudtaglys". It exists already from provider "GenericMetadataProvider"! Failed to add a second with the same UID from provider "GenericMetadataProvider"!
2019-03-19 18:52:50.479 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add "Metadata" with key "channel:stue_sov_OEV". It exists already from provider "GenericMetadataProvider"! Failed to add a second with the same UID from provider "GenericMetadataProvider"!
2019-03-19 18:52:50.484 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add "Metadata" with key "channel:stue_sov_OEH". It exists already from provider "GenericMetadataProvider"! Failed to add a second with the same UID from provider "GenericMetadataProvider"!
2019-03-19 18:52:50.511 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add "Metadata" with key "channel:kontor". It exists already from provider "GenericMetadataProvider"! Failed to add a second with the same UID from provider "GenericMetadataProvider"!
2019-03-19 18:52:50.520 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add "Metadata" with key "channel:bryggers_DimmerLys". It exists already from provider "GenericMetadataProvider"! Failed to add a second with the same UID from provider "GenericMetadataProvider"!
2019-03-19 18:52:50.525 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add "Metadata" with key "channel:bryggers_Skablys". It exists already from provider "GenericMetadataProvider"! Failed to add a second with the same UID from provider "GenericMetadataProvider"!
2019-03-19 18:52:50.535 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add "Metadata" with key "channel:lille_bad_OEV". It exists already from provider "GenericMetadataProvider"! Failed to add a second with the same UID from provider "GenericMetadataProvider"!
2019-03-19 18:52:50.546 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add "Metadata" with key "channel:casperDimmerLys". It exists already from provider "GenericMetadataProvider"! Failed to add a second with the same UID from provider "GenericMetadataProvider"!
2019-03-19 18:52:50.555 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add "Metadata" with key "channel:amanda_OEH". It exists already from provider "GenericMetadataProvider"! Failed to add a second with the same UID from provider "GenericMetadataProvider"!
2019-03-19 18:52:50.559 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add "Metadata" with key "channel:amanda_OEV". It exists already from provider "GenericMetadataProvider"! Failed to add a second with the same UID from provider "GenericMetadataProvider"!
2019-03-19 18:52:50.568 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add "Metadata" with key "channel:marc_OEH". It exists already from provider "GenericMetadataProvider"! Failed to add a second with the same UID from provider "GenericMetadataProvider"!
2019-03-19 18:52:50.572 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add "Metadata" with key "channel:marc_OEV". It exists already from provider "GenericMetadataProvider"! Failed to add a second with the same UID from provider "GenericMetadataProvider"!
2019-03-19 18:52:50.584 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add "Metadata" with key "channel:aktivitetLysKonstant". It exists already from provider "GenericMetadataProvider"! Failed to add a second with the same UID from provider "GenericMetadataProvider"!
2019-03-19 18:52:50.588 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add "Metadata" with key "channel:aktivitetBeboet". It exists already from provider "GenericMetadataProvider"! Failed to add a second with the same UID from provider "GenericMetadataProvider"!
2019-03-19 18:52:50.593 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add "Metadata" with key "channel:aktivitetUBeboet". It exists already from provider "GenericMetadataProvider"! Failed to add a second with the same UID from provider "GenericMetadataProvider"!
2019-03-19 18:52:50.607 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add "Metadata" with key "channel:garage_ydoer". It exists already from provider "GenericMetadataProvider"! Failed to add a second with the same UID from provider "GenericMetadataProvider"!
2019-03-19 18:52:50.614 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add "Metadata" with key "channel:garage_bryggers_NV". It exists already from provider "GenericMetadataProvider"! Failed to add a second with the same UID from provider "GenericMetadataProvider"!
2019-03-19 18:52:50.622 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add "Metadata" with key "channel:lys_indgangspotKonstant". It exists already from provider "GenericMetadataProvider"! Failed to add a second with the same UID from provider "GenericMetadataProvider"!
2019-03-19 18:52:50.628 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add "Metadata" with key "channel:lys_haven". It exists already from provider "GenericMetadataProvider"! Failed to add a second with the same UID from provider "GenericMetadataProvider"!
This error (warning) goes for all items I have, which has additional channel definition:
Switch stort_badDimmerLys "Halogenlys i StortBad [%s]" <cu_spot> (vLys) [ "Lighting" ] { channel="ihc:controller:elko:stortbad_dimmer_fb", channel="ihc:controller:elko:stortbad_dimmer_state", autoupdate="false" }
Switch sove_lampeudtaglys "Lampeudtag i soveværelset [%s]" <light> (vLys) [ "Lighting" ] { channel="ihc:controller:elko:sove_80mm_fb", channel="ihc:controller:elko:sove_80mm_state", autoupdate="false" }
Switch stue_sov_OEV "Stue M1 [%s]" <light> (vLys) [ "Lighting" ] { channel="ihc:controller:elko:stuen_m1", channel="ihc:controller:elko:stuen_m1_state", autoupdate="false" }
Switch stue_sov_OEH "Stue M2 [%s]" <light> (vLys) [ "Lighting" ] { channel="ihc:controller:elko:stuen_m2", channel="ihc:controller:elko:stuen_m2_state", autoupdate="false" }
Switch kontor "Loftlys i kontoret [%s]" <light> (vLys) [ "Lighting" ] { channel="ihc:controller:elko:kontor_80mm", channel="ihc:controller:elko:kontor_80mm_state", autoupdate="false" }
Switch bryggers_DimmerLys "Bryggers Halogenlys [%s]" <cu_spot> (vLys) [ "Lighting" ] { channel="ihc:controller:elko:bryggers_dimmer_fb", channel="ihc:controller:elko:bryggers_dimmer_state", autoupdate="false" }
Switch bryggers_Skablys "Bryggers Skablys [%s]" <light> (vLys) [ "Lighting" ] { channel="ihc:controller:elko:bryggers_skabslys_fb", channel="ihc:controller:elko:bryggers_skabslys_state", autoupdate="false" }
Switch lille_bad_OEV "Lille Bad Lys [%s]" <cu_spot> (vLys) [ "Lighting" ] { channel="ihc:controller:elko:lillebad_dimmer_fb", channel="ihc:controller:elko:lillebad_dimmer_state", autoupdate="false" }
Switch casperDimmerLys "Loftlys i Caspers værelse [%s]" <light> (vLys) [ "Lighting" ] { channel="ihc:controller:elko:casper_dimmer_fb", channel="ihc:controller:elko:casper_dimmer_state", autoupdate="false" }
Switch amanda_OEH "Spotlys i Amandas værelse [%s]" <cu_spot> (vLys) [ "Lighting" ] { channel="ihc:controller:elko:amanda_dimmer_fb", channel="ihc:controller:elko:amanda_dimmer_state", autoupdate="false" }
Switch amanda_OEV "Lampeudtag i Amandas værelse [%s]" <light> (vLys) [ "Lighting" ] { channel="ihc:controller:elko:amanda_80mm_fb", channel="ihc:controller:elko:amanda_80mm_state", autoupdate="false" }
Switch marc_OEH "Spotlys i Marcs værelse [%s]" <cu_spot> (vLys) [ "Lighting" ] { channel="ihc:controller:elko:marc_dimmer_fb", channel="ihc:controller:elko:marc_dimmer_state", autoupdate="false" }
Switch marc_OEV "Lampeudtag i Marcs værelse [%s]" <light> (vLys) [ "Lighting" ] { channel="ihc:controller:elko:marc_80mm_fb", channel="ihc:controller:elko:marc_80mm_state", autoupdate="false" }
Switch aktivitetLysKonstant "Konstantlys i aktivitetrum [%s]" <light> [ "Lighting" ] { channel="ihc:controller:elko:aktivitet_dimmer_konst", channel="ihc:controller:elko:aktivitet_konst_state", autoupdate="false" }
Switch aktivitetBeboet "Beboet tilstand [MAP(nilan_on_off.map):%s]" <cu_switch> [ "Lighting" ] { channel="ihc:controller:elko:aktivitet_beboet", channel="ihc:controller:elko:aktivitet_beboet_state", autoupdate="false" }
Switch aktivitetUBeboet "Ubeboet tilstand [MAP(nilan_on_off.map):%s]" <cu_switch> [ "Lighting" ] { channel="ihc:controller:elko:aktivitet_ubeboet", channel="ihc:controller:elko:aktivitet_ubeboet_state", autoupdate="false" }
Switch garage_ydoer "Garage lys konstant [%s]" <light> [ "Lighting" ] { channel="ihc:controller:elko:garagelys_konst", channel="ihc:controller:elko:garagelys_konst_state", autoupdate="false" }
Switch garage_bryggers_NV "Garageporten [%s]" <light> [ "Switchable" ] { channel="ihc:controller:elko:garageport", channel="ihc:controller:elko:garageport_state", autoupdate="false" }
Switch lys_indgangspotKonstant "Udvendiglys Indgangsparti på konstant [%s]" <light> { channel="ihc:controller:elko:indgangsparti_konst", channel="ihc:controller:elko:indgangsparti_konst_state", autoupdate="false" }
Switch lys_haven "Lyset i haven [%s]" <light> (vLys) [ "Lighting" ] { channel="ihc:controller:elko:have_dimmer_fb", channel="ihc:controller:elko:have_dimmer_state", autoupdate="false" }
It has also been noted with an fix (I guess) in this message:
So if one remove the additional channel definition, the warning should be gone. I havn´t tried the suggestion, as I believe this is an issue in openhab, which needs to be fixed. Or is it suppose to be like the suggested fix??
Comment - there is a section about multiple bindings in the docs.
If dealing with multiple channels, and the correct/preferred method is
channel = "xx" , "yy"
perhaps this needs adding to docs
Sounds like this isn’t quite right with profile as well though?
At the bottom of the link there is an example which used mutiple channels (Multi-channel Linking)… :
Color Bedroom_Light { channel="hue:0210:1:bulb1:color", channel="serialbutton:button:mybutton:button" [profile="rawbutton-toggle-switch"] }
But this will result in a warning when used. And I believe it´s been there for quite some time now (since 2.4M1).
So there is, completely missed that at first reading
I know the feeling
So I guess this calls for an issue then.
