Hello
I have programmed some lights to turn on and off with the sun thanks to ASTRO BUILDING, what I needed now is to be able to decide when they turn on or off because I do not want them to stay overnight, now I do it with a simple rule off but I would like to choose the time and day.
I have tried to modify the ALAMARCLOCK rule but I am not able to make it work by attaching my rule and the file of items.
import org.openhab.core.library.types.*
import org.openhab.core.persistence.*
import org.openhab.model.script.actions.*
import org.joda.time.*
import java.util.ArrayList
rule "Programacion luces valla"
Item Program_Luces_valla received update or
Time cron "0 00 02 * * ?"
//Time cron "0 27 * * * ?"
var ArrayList dayOfWeekSetting = newArrayList(
Monday_Program_Luces_valla.state,
Tuesday_Program_Luces_valla.state,
Wednesday_Program_Luces_valla.state,
Thursday_Program_Luces_valla.state,
Friday_Program_Luces_valla.state,
Saturday_Program_Luces_valla.state,
Sunday_Program_Luces_valla.state
if (dayOfWeekSetting.get(now.getDayOfWeek-1) == OFF){
sendCommand(Program_Luces_valla_DayofWeek, OFF)
return false
if (Program_Luces_valla.state == ON) {
logInfo("ScheduleProgramB", "Running Program B Scheduler")
// convert our start time to a joda.time.DateTime for today
var int minutes = (Program_Luces_valla_StartTime_Minutes.state as DecimalType).intValue()
var int hours = (Program_Luces_valla_StartTime_Hours.state as DecimalType).intValue()
var DateTime startTime = parse(now.getYear() + "-" + now.getMonthOfYear() + "-" + now.getDayOfMonth() + "T" + hours + ":" + minutes)
//var DateTime startTime = now
logInfo("ScheduleProgramB", "Start Time: " + startTime)
var DateTime endTime
if (startTime.isAfter(now)){
if (Program_Luces_valla_StartTime)
sendCommand(Lucesvalla, OFF)
rule "Set Programa apagado Startime"
Item Program_Luces_valla_StartTime_Minutes received update or
Item Program_Luces_valla_StartTime_Hours received update
if (Program_Luces_valla_StartTime_Minutes.state == 60){
Program_Luces_valla_StartTime_Minutes.sendCommand(0)
if (Program_Luces_valla_StartTime_Hours.state == 24){
Program_Luces_valla_StartTime_Hours.sendCommand(0)
// work out when the program is to start
// update the alarm display time
Program_Luces_valla_StartTime.sendCommand(String::format("%02d:%02d", startTime.getHourOfDay(), startTime.getMinuteOfHour()))
rule "Programacion luces encendido valla"
Item Program_Luces_valla_ON received update or
Time cron "0 0 0 * * ?"
Monday_Program_Luces_valla_ON.state,
Tuesday_Program_Luces_valla_ON.state,
Wednesday_Program_Luces_valla_ON.state,
Thursday_Program_Luces_valla_ON.state,
Friday_Program_Luces_valla_ON.state,
Saturday_Program_Luces_valla_ON.state,
Sunday_Program_Luces_valla_ON.state
sendCommand(Program_Luces_valla_ON_DayofWeek, OFF)
return false
if (Program_Luces_valla_ON.state == ON) {
var int minutes = (Program_Luces_ON_valla_StartTime_Minutes.state as DecimalType).intValue()
var int hours = (Program_Luces_valla_ON_StartTime_Hours.state as DecimalType).intValue()
sendCommand(Lucesvalla, ON)
Item Program_Luces_valla_ON_StartTime_Minutes received update or
Item Program_Luces_valla_ON_StartTime_Hours received update
if (Program_Luces_valla_ON_StartTime_Minutes.state == 60){
Program_Luces_valla_ON_StartTime_Minutes.sendCommand(0)
if (Program_Luces_valla_ON_StartTime_Hours.state == 24){
Program_Luces_valla_ON_StartTime_Hours.sendCommand(0)
var int minutes = (Program_Luces_valla_ON_StartTime_Minutes.state as DecimalType).intValue()
Program_Luces_valla_ON_StartTime.sendCommand(String::format("%02d:%02d", startTime.getHourOfDay(), startTime.getMinuteOfHour()))
Items
/* Program luces valla Settings */
Switch Program_Luces_valla "Program B [%s]" <power> (ProgramBSettings)
Switch Program_Luces_valla_DayofWeek "Program B Day Of Week [%s]" <power> (ProgramBSettings)
String Program_Luces_valla_StartTime "Start Time [%s]" <calendar> (ProgramBSettings)
Number Program_Luces_valla_StartTime_Hours "Hours [%d]" (ProgramBSettings)
Number Program_Luces_valla_StartTime_Minutes "Minutes [%d]" (ProgramBSettings)
Switch Monday_Program_Luces_valla "Monday [%s]" <power> (ProgramBSettings)
Switch Tuesday_Program_Luces_valla "Tuesday [%s]" <power> (ProgramBSettings)
Switch Wednesday_Program_Luces_valla "Wednesday [%s]" <power> (ProgramBSettings)
Switch Thursday_Program_Luces_valla "Thursday [%s]" <power> (ProgramBSettings)
Switch Friday_Program_Luces_valla "Friday [%s]" <power> (ProgramBSettings)
Switch Saturday_Program_Luces_valla "Saturday [%s]" <power> (ProgramBSettings)
Switch Sunday_Program_Luces_valla "Sunday [%s]" <power> (ProgramBSettings)
Switch Program_Luces_valla_ON "Program B [%s]" <power> (ProgramBSettings)
Switch Program_Luces_valla_ON_DayofWeek "Program B Day Of Week [%s]" <power> (ProgramBSettings)
String Program_Luces_valla_ON_StartTime "Start Time [%s]" <calendar> (ProgramBSettings)
Number Program_Luces_valla_ON_StartTime_Hours "Hours [%d]" (ProgramBSettings)
Number Program_Luces_valla_ON_StartTime_Minutes "Minutes [%d]" (ProgramBSettings)
Switch Monday_Program_Luces_valla_ON "Monday [%s]" <power> (ProgramBSettings)
Switch Tuesday_Program_Luces_valla_ON "Tuesday [%s]" <power> (ProgramBSettings)
Switch Wednesday_Program_Luces_valla_ON "Wednesday [%s]" <power> (ProgramBSettings)
Switch Thursday_Program_Luces_valla_ON "Thursday [%s]" <power> (ProgramBSettings)
Switch Friday_Program_Luces_valla_ON "Friday [%s]" <power> (ProgramBSettings)
Switch Saturday_Program_Luces_valla_ON "Saturday [%s]" <power> (ProgramBSettings)
Switch Sunday_Program_Luces_valla_ON "Sunday [%s]" <power> (ProgramBSettings)
Switch Lucesvalla "Luces Valla" <switch> (TodasLucesCalle_GRP) { souliss="T11:1:2", autoupdate="false" }
a greeting I hope your help.
