I have few questions regarding the programs from the openhabian-config’s menu (OpenHabian v2.0.0-1).
From what I understand: options 1…5 are already pre-installed with openHABian.
I need to choose which of the following programs I want to install.
I tried to read and understand the meaning of some of the options and to be honest - some of them are not so clear to me what functionality they supply and what is the benefit of having them installed, what will not work unless I install them.
My goal is to be able to run mySensors with openHAB at my home and be able to control it from the LAN and also from the WAN.
I tried to install HomeGear and the installation failed (just as it did during the last time I tried to install it:
the result is here:
[openHABian] Checking for root privileges... OK
[openHABian] Checking for default Raspbian user:passwd combination... OK
[openHABian] Setting up the Homematic CCU2 emulation software Homegear... --2017-02-09 17:53:38-- http://homegear.eu/packages/Release.key
Resolving homegear.eu (homegear.eu)... 138.201.146.201, 2a01:4f8:172:19a5::3
Connecting to homegear.eu (homegear.eu)|138.201.146.201|:80... failed: Connection timed out.
Connecting to homegear.eu (homegear.eu)|2a01:4f8:172:19a5::3|:80... failed: Network is unreachable.
gpg: no valid OpenPGP data found.
$ apt update
Ign http://dl.bintray.com stable InRelease
Hit http://mirrordirector.raspbian.org jessie InRelease
Get:1 http://dl.bintray.com stable Release.gpg [821 B]
Hit http://archive.raspberrypi.org jessie InRelease
Get:2 https://homegear.eu jessie/ InRelease [2,384 B]
Get:3 http://dl.bintray.com stable Release [6,050 B]
Hit http://mirrordirector.raspbian.org jessie/main armhf Packages
Ign https://homegear.eu jessie/ InRelease
Hit http://archive.raspberrypi.org jessie/main armhf Packages
Get:4 https://homegear.eu jessie/ Packages [11.4 kB]
Hit http://mirrordirector.raspbian.org jessie/contrib armhf Packages
Hit http://mirrordirector.raspbian.org jessie/non-free armhf Packages
Get:5 http://dl.bintray.com stable/main armhf Packages [666 B]
Hit http://mirrordirector.raspbian.org jessie/firmware armhf Packages
Get:6 https://homegear.eu jessie/ Translation-en_US [232 B]
Get:7 https://homegear.eu jessie/ Translation-en [229 B]
Get:8 https://homegear.eu jessie/ Translation-en_US.UTF-8 [238 B]
Get:9 https://homegear.eu jessie/ Translation-en_US [232 B]
Get:10 https://homegear.eu jessie/ Translation-en [229 B]
Get:11 https://homegear.eu jessie/ Translation-en_US.UTF-8 [238 B]
Get:12 https://homegear.eu jessie/ Translation-en_US [232 B]
Get:13 https://homegear.eu jessie/ Translation-en [229 B]
Get:14 https://homegear.eu jessie/ Translation-en_US.UTF-8 [238 B]
Get:15 https://homegear.eu jessie/ Translation-en_US [232 B]
Get:16 https://homegear.eu jessie/ Translation-en [229 B]
Get:17 https://homegear.eu jessie/ Translation-en_US.UTF-8 [238 B]
Get:18 https://homegear.eu jessie/ Translation-en_US [232 B]
Ign https://homegear.eu jessie/ Translation-en_US
Get:19 https://homegear.eu jessie/ Translation-en [229 B]
Get:20 https://homegear.eu jessie/ Translation-en_US.UTF-8 [238 B]
Ign https://homegear.eu jessie/ Translation-en_US.UTF-8
Ign http://dl.bintray.com stable/main Translation-en_US
Ign http://dl.bintray.com stable/main Translation-en_US.UTF-8
Ign http://archive.raspberrypi.org jessie/main Translation-en_US
Ign http://archive.raspberrypi.org jessie/main Translation-en_US.UTF-8
Hit http://ppa.launchpad.net trusty InRelease
Ign http://mirrordirector.raspbian.org jessie/contrib Translation-en_US
Hit http://ppa.launchpad.net trusty/main Sources
Hit http://ppa.launchpad.net trusty/main armhf Packages
Ign http://mirrordirector.raspbian.org jessie/contrib Translation-en_US.UTF-8
Hit http://ppa.launchpad.net trusty/main Translation-en
Ign http://mirrordirector.raspbian.org jessie/firmware Translation-en_US
Ign http://mirrordirector.raspbian.org jessie/firmware Translation-en_US.UTF-8
Ign http://mirrordirector.raspbian.org jessie/main Translation-en_US
Ign http://mirrordirector.raspbian.org jessie/main Translation-en_US.UTF-8
Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en_US
Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en_US.UTF-8
Fetched 21.3 kB in 8s (2,381 B/s)
Reading package lists... Done
Building dependency tree
All packages are up to date.
W: GPG error: https://homegear.eu jessie/ InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 898BB4C44F646455
$ apt -y install homegear homegear-homematicbidcos homegear-homematicwired
The following extra packages will be installed:
aspell aspell-en dictionaries-common emacsen-common enchant hunspell-en-us libaspell15
libcurl4-gnutls-dev libenchant1c2a libgnutlsxx28 libhomegear-base libhunspell-1.3-0 libltdl7
liblzo2-2 libmcrypt4 libmysqlclient18 libqdbm14 libtext-iconv-perl libxslt1.1 mysql-common
p7zip-full python-lzo
Suggested packages:
aspell-doc spellutils wordlist hunspell openoffice.org-hunspell openoffice.org-core libcurl4-doc
libcurl3-dbg libgnutls28-dev libidn11-dev libkrb5-dev libldap2-dev librtmp-dev libssh2-1-dev
pkg-config zlib1g-dev libenchant-voikko libmcrypt-dev mcrypt p7zip-rar
The following NEW packages will be installed:
aspell aspell-en dictionaries-common emacsen-common enchant homegear homegear-homematicbidcos
homegear-homematicwired hunspell-en-us libaspell15 libcurl4-gnutls-dev libenchant1c2a
libgnutlsxx28 libhomegear-base libhunspell-1.3-0 libltdl7 liblzo2-2 libmcrypt4 libmysqlclient18
libqdbm14 libtext-iconv-perl libxslt1.1 mysql-common p7zip-full python-lzo
0 upgraded, 25 newly installed, 0 to remove and 0 not upgraded.
Need to get 30.7 MB of archives.
After this operation, 152 MB of additional disk space will be used.
WARNING: The following packages cannot be authenticated!
libhomegear-base homegear homegear-homematicbidcos homegear-homematicwired
E: There are problems and -y was used without --force-yes
FAILED
After I get the fail result, the openhabian-config is not showing the menu anymore and I get the prompt.
I know that I need the MQTT broker so I installed the mosquitto service.
Grafana seems to me like something that will be nice to have - even though I am not sure how I will be able to use it from within openHAB.
Since I currently am not connecting 1wire devices to the pi I understand that OWServer is not needed.
Not sure what is the use of:
Nginx reverse proxy with password authentication and/or HTTPS access (incl. Let’s Encrypt certificate)
Karaf remote console
KNX daemon
