Hello, what is the proper to way to update from a 2.3.0 snaphot to the 2.3.0 stable release ?
I’m running a raspberry pi, openhabianpi and openHAB 2.3.0~20180505223259-1 (Build #1272).
I switched to the snapshot releases a while ago using this command
echo 'deb https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable main' | sudo tee /etc/apt/sources.list.d/openhab2.list
Now, I tried to update with openhabian-config but after reboot, nothing worked at all.
The only things unusual when updating where some warning about some ‘readme.txt’ file being already present
and asking if I want to overwrite, also addons.cfg and runtimecfg files.
