Zurisee
(Dieter Stokar)
February 2, 2016, 2:42pm
1
Hi
in the debug log I get an message:
"ProtocolValue null is not configured. If the command is a state this will result in no error."
Can anybody tell me what that means: “…command is a state…” (sounds rather puzzling to me)
Background: I’m trying to get an EnOcean actuator (Omnio UPS230/08) running on V1.8.0). Item:
Switch Eno1 "Eno1" (All) { enocean="{ id=FF:9B:E2:01, eep=D2:01:01, channel=B }" }
As soon as I activate the item in the web UI I get the above message.
Does it have to do with EnOcean or is it something else?
Thanks,
Dieter
watou
(John Cocula)
February 2, 2016, 2:50pm
2
Since it’s a debug message from the EnOcean binding, it is not reporting a problem.
Zurisee
(Dieter Stokar)
February 2, 2016, 3:06pm
3
Hm, not sure whether that helps… (thanks anyway!)
I had forgotten to mention that the device is not responding. So, I’m still at a dead end.
Any other hints?
BTW, has anybody got EnOcean actuators working? Or am I chasing a red herring…?
watou
(John Cocula)
February 2, 2016, 3:13pm
4
I don’t use the binding so I don’t know more. I see an issue reported a week ago that is possibly related. I will add some tags to your post in hopes of other users commenting.
granija
(Diego Cimadevilla)
May 1, 2016, 12:28pm
5
Are you get to know what means this “issue”. I have same DEBUG message and my relays not react when I change the UI switch,
Thanks in advance.
schnibel
(Michel)
November 30, 2016, 10:37pm
6
I have exactly the same message, and my equipment does not react…
Did you find a solution ?
Zurisee
(Dieter Stokar)
December 1, 2016, 7:57am
7
Sorry, no. I ran out of time and had to abandon the project for the time being.
I’d still be interested in a solution, too.
To rephrase the question:
Can anybody publish an example of an EnOcean actor integration?
(One that has been tested and verified, if possible.)
Thanks!
meCtiv
(Christian)
December 30, 2016, 2:12pm
8
Hello!
Just started with openHAB and I am facing the same problem.
Will welcome any reference.
Cheers
Christian
