adm105
(hjs)
November 28, 2022, 2:57am
#1
The Channel Call List from Binding TR 064 provides this information after the end of a connection and expands the 7-day list that is stored in openHAB 3 as item ‘FritzBox_CallList7’:
2022-11-25 15:41:15.966 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'FritzBox_CallList7' changed from [{"localNumber":"654321","remoteNumber":"0301234567","date":"2022-11-24T18:21:00+01","type":3,"duration":5},
{"localNumber":"654321","remoteNumber":"01727654321","date":"2022-11-24T18:19:00+01","type":1,"duration":2},
The list is sorted in descending order, most recent connection first.
How can I now filter out the values “type” and “duration” of the last connection within a rule in order to then transfer them to existing items?
I hope you can help me.
rossko57
(Rossko57)
November 28, 2022, 10:44am
#2
“Last” meaning “most recent” i.e. first in the list?
Raw data appears to be JSON, so I’d use transform JSONPATH in a rule with something like $.[0].type
adm105
(hjs)
November 28, 2022, 1:18pm
#3
“Last” means “last connection” and you got it right, it’s the newest one in the list.
However, I am not familiar with JSONPATH. Could she complete the following rule?
rule "Anruf beendet"
Item fritzCallRinging changed from DIALING to IDLE
here your idea please!
rossko57
(Rossko57)
November 28, 2022, 1:28pm
#4
Suggested examples
Yes.
If you want to use the JSONPATH transformation, you’ll probably do one element at a time, because the transformation only returns one string.
Examples
You can get it to return a single string that looks like an array “[blah, bleh]” which you can parse further in your rule (e.g. split on commas) but likely easier to get one at a time.
Complex example doing that
The openHAB JSONPATH Transformation Service is an optional add-on, you will need to install it.
