Using Windows with Visual code to connect to the Raspberry Pi
I installed raspberry pi and worked good but KPN cancelled internet and blocked my raspberry IP address. Cannot save files anymore in the folder.
Did I miss some security settings ?
Looks like I have an open port or something.
The openhab files are still in the folder network / ip address /openhab-conf
But my rules do not work anymore. The frontail log shows that all my sensors respond and work perfectly but openhab rules do not work anymore. Also I cannot save the default.rules items and sitemap under the same name anymore : no permission…
The provider blocked something.
Nothing you describe sounds like something your internet provider could have done. They can cut off your internet but they can’t break your LAN. And they certainly can’t break your OH config.
2019-03-30 16:45:27.876 [WARN ] [me.core.internal.events.EventHandler] - Dispatching event to subscriber ‘org.eclipse.smarthome.io.monitor.internal.EventLogger@1fd7f58’ takes more than 5000ms.
My Paper UI is showing all things online. And fronttail do show all sensors on off etc.
Sitemap groups are there but no single item is shouwing within the group.
Events log looks fine with updates 2019-03-30 19:45:40.057 [me.event.ThingUpdatedEvent] - Thing ‘zigbee:device:04000BE2:d0cf5efffe1d4ff9’ has been updated.
2019-03-30 19:45:42.964 [me.event.ThingUpdatedEvent] - Thing ‘zigbee:coordinator_telegesis:04000BE2’ has been updated.
2019-03-30 19:45:44.722 [me.event.ThingUpdatedEvent] - Thing ‘zigbee:device:04000BE2:90fd9ffffef74ff2’ has been updated.
2019-03-30 19:45:48.643 [me.event.ThingUpdatedEvent] - Thing ‘zigbee:device:04000BE2:000b57fffe906026’ has been updated.
