Proxmox zigbee stick passthrough
Hey guys,
Anyone manage to run proxmox with a zigbee stick passthrough?
Passing the USB stick through to a CT requires me to lookup /dev/serial/by-id every reboot and figure out which values to pass, then do a chmod on /dev/ttyACM0 to get write access in the CT and then reboot the CT for the changes to take effect.
Passing the USB stick to a VM is even worse as passing the entire USB port results in there not being /dev/ttyACM0 being created at all in the VM despite it going missing on the host side as well.
Anyone successfully made this work in their setup?
Thanks!
