result = actions.get("pushover", "pushover:pushover-account:my-account").sendPriorityMessage(messageText, messageTitle, messagePriority)
According to the docs, the Pushover actions, e.g. sendMessage() should return a boolean value. This too worked with openHAB 2, I could evaluate the return value and send a mail if Pushover failed.
In openHAB 3 there seems to be no such return value, only the receipt when sending high priority messages with sendPriorityMessage().
I see the same messages in my log. At first I thought that it only happens when using the .sendPriorityMessage method, but after looking deeper into this I found out that it is logged for teh sendMessage method as well.
You are not alone
EDIT: I do get a boolean result when the message is sent out, but not when the exception occurs. I worked around this by using the following code:
I tried this with the version from mid January and I am pretty sure, that I got no return value. But I will try it again with the current milestone build.
and it reports True when the message is sent over pushover and nothing when the exception is spit out to the logs.
Have you investigated further into this issue by inceasing the log level for the binding? It seems to me that once a pushover is sent out successfully, subsequent pushovers are also successful.
I checked this again with 3.1 M2 and now I too get a boolean as result whenever no exception is raised. But only when using “sendMessage()”. This is probably a bug in the documentation, where it is stated " All actions return a Boolean value to indicate if the message was sent successfully or not."
Now I have set the log level to TRACE, I will report back if this gives any interesting information. But, as always when testing, currently everything works as expected
Thanks for sharing this, good idea! I will adopt this, luckily I have already encapsulated sending Pushover message in my own library function.
In the meantime I found the following information in my log file:
2021-03-06 15:00:30.348 [TRACE] [nal.connection.PushoverAPIConnection] - Pushover request: POST - URL = 'https://api.pushover.net/1/messages.json'
2021-03-06 15:00:30.350 [TRACE] [nal.connection.PushoverAPIConnection] - Pushover request body: 'org.eclipse.jetty.client.util.MultiPartContentProvider@6753ce04'
2021-03-06 15:00:30.364 [DEBUG] [nal.connection.PushoverAPIConnection] - Exception occurred during execution: java.io.EOFException: HttpConnectionOverHTTP@58b1280c::DecryptedEndPoint@65152ed5{api.pushover.net/104.20.124.71:443<->/192.168.10.50:51982,CLOSED,fill=-,flush=W,to=627073/0}
java.util.concurrent.ExecutionException: java.io.EOFException: HttpConnectionOverHTTP@58b1280c::DecryptedEndPoint@65152ed5{api.pushover.net/104.20.124.71:443<->/192.168.10.50:51982,CLOSED,fill=-,flush=W,to=627073/0}
at org.eclipse.jetty.client.util.FutureResponseListener.getResult(FutureResponseListener.java:118) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.util.FutureResponseListener.get(FutureResponseListener.java:101) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.HttpRequest.send(HttpRequest.java:685) ~[bundleFile:9.4.20.v20190813]
at org.openhab.binding.pushover.internal.connection.PushoverAPIConnection.executeRequest(PushoverAPIConnection.java:150) [bundleFile:?]
at org.openhab.binding.pushover.internal.connection.PushoverAPIConnection.post(PushoverAPIConnection.java:134) [bundleFile:?]
at org.openhab.binding.pushover.internal.connection.PushoverAPIConnection.sendPriorityMessage(PushoverAPIConnection.java:83) [bundleFile:?]
at org.openhab.binding.pushover.internal.handler.PushoverAccountHandler.sendPriorityMessage(PushoverAccountHandler.java:145) [bundleFile:?]
at org.openhab.binding.pushover.internal.actions.PushoverActions.sendPriorityMessage(PushoverActions.java:146) [bundleFile:?]
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:190) [bundleFile:?]
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:208) [bundleFile:?]
at org.python.core.PyObject.__call__(PyObject.java:512) [bundleFile:?]
at org.python.core.PyObject.__call__(PyObject.java:517) [bundleFile:?]
at org.python.core.PyMethod.__call__(PyMethod.java:171) [bundleFile:?]
at personal.mylib$py.push_pushover$22(/etc/openhab/automation/lib/python/personal/mylib.py:217) [bundleFile:?]
at personal.mylib$py.call_function(/etc/openhab/automation/lib/python/personal/mylib.py) [bundleFile:?]
at org.python.core.PyTableCode.call(PyTableCode.java:173) [bundleFile:?]
at org.python.core.PyBaseCode.call(PyBaseCode.java:168) [bundleFile:?]
at org.python.core.PyFunction.__call__(PyFunction.java:437) [bundleFile:?]
at personal.mylib$py.notifyMe$23(/etc/openhab/automation/lib/python/personal/mylib.py:238) [bundleFile:?]
at org.python.core.PyBaseCode.call(PyBaseCode.java:306) [bundleFile:?]
at org.python.core.PyFunction.function___call__(PyFunction.java:474) [bundleFile:?]
at org.python.core.PyFunction.__call__(PyFunction.java:469) [bundleFile:?]
at org.python.pycode._pyx101.notifyHunidityLow$1(<script>:55) [bundleFile:?]
at org.python.pycode._pyx101.call_function(<script>) [bundleFile:?]
at org.python.core.PyBaseCode.call(PyBaseCode.java:134) [bundleFile:?]
at org.python.core.PyFunction.__call__(PyFunction.java:416) [bundleFile:?]
at core.rules$py.execute$6(/etc/openhab/automation/lib/python/core/rules.py:108) [bundleFile:?]
at core.rules$py.call_function(/etc/openhab/automation/lib/python/core/rules.py) [bundleFile:?]
at org.python.core.PyFunction.__call__(PyFunction.java:464) [bundleFile:?]
at org.python.core.PyObject._callextra(PyObject.java:589) [bundleFile:?]
at core.log$py.wrapper$7(/etc/openhab/automation/lib/python/core/log.py:114) [bundleFile:?]
at core.log$py.call_function(/etc/openhab/automation/lib/python/core/log.py) [bundleFile:?]
at org.python.core.PyBaseCode.call(PyBaseCode.java:197) [bundleFile:?]
at org.python.core.PyFunction.__call__(PyFunction.java:485) [bundleFile:?]
at org.python.core.PyMethod.instancemethod___call__(PyMethod.java:237) [bundleFile:?]
at org.python.core.PyMethod.__call__(PyMethod.java:228) [bundleFile:?]
at org.python.core.PyMethod.__call__(PyMethod.java:218) [bundleFile:?]
at org.python.core.PyMethod.__call__(PyMethod.java:213) [bundleFile:?]
at org.python.core.PyObject._jcallexc(PyObject.java:3565) [bundleFile:?]
at org.python.core.PyObject._jcall(PyObject.java:3598) [bundleFile:?]
at org.python.proxies.core.rules$_FunctionRule$213.execute(Unknown Source) [bundleFile:?]
at org.openhab.core.automation.module.script.rulesupport.shared.simple.SimpleRuleActionHandlerDelegate.execute(SimpleRuleActionHandlerDelegate.java:34) [bundleFile:?]
at org.openhab.core.automation.module.script.rulesupport.internal.delegates.SimpleActionHandlerDelegate.execute(SimpleActionHandlerDelegate.java:59) [bundleFile:?]
at org.openhab.core.automation.internal.RuleEngineImpl.executeActions(RuleEngineImpl.java:1179) [bundleFile:?]
at org.openhab.core.automation.internal.RuleEngineImpl.runRule(RuleEngineImpl.java:987) [bundleFile:?]
at org.openhab.core.automation.internal.TriggerHandlerCallbackImpl$TriggerData.run(TriggerHandlerCallbackImpl.java:89) [bundleFile:?]
Caused by: java.io.EOFException: HttpConnectionOverHTTP@58b1280c::DecryptedEndPoint@65152ed5{api.pushover.net/104.20.124.71:443<->/192.168.10.50:51982,CLOSED,fill=-,flush=W,to=627073/0}
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.earlyEOF(HttpReceiverOverHTTP.java:335) ~[?:?]
at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:1526) ~[?:?]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.shutdown(HttpReceiverOverHTTP.java:209) ~[?:?]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.process(HttpReceiverOverHTTP.java:147) ~[?:?]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.receive(HttpReceiverOverHTTP.java:73) ~[?:?]
at org.eclipse.jetty.client.http.HttpChannelOverHTTP.receive(HttpChannelOverHTTP.java:133) ~[?:?]
at org.eclipse.jetty.client.http.HttpConnectionOverHTTP.onFillable(HttpConnectionOverHTTP.java:154) ~[?:?]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) ~[?:?]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.onFillable(SslConnection.java:426) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:320) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection$2.succeeded(SslConnection.java:158) ~[?:?]
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129) ~[?:?]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:367) ~[?:?]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:782) ~[?:?]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:918) ~[?:?]
... 1 more
2021-03-06 15:00:30.404 [WARN ] [org.openhab.core.automation.mylib.py] - Pushover failed with exception:
Any Updates on this?
Did someone open an issue on github already?
To be precise:
Very randomly the following error message appears in the logs and no pushover message is sent:
Script execution of rule with UID 'hm-sonstige-5' failed: java.io.EOFException: HttpConnectionOverHTTP@d761b68::DecryptedEndPoint@3b78ddb9{api.pushover.net/104.20.125.71:443<->/192.168.178.2:47218,OPEN,fill=-,flush=F,to=82112373/0} in hm-sonstige
Seconds later the rule works like a charm for multiple times.
Very strange!
