I’ve configured the pushover settings in openhab.cfg with the proper api and userkey token (minimal configuration).
When adding a simple pushover action in openhab.rules, an error in the log is generated :
2016-07-27 18:59:41.749 [ERROR] [o.a.pushover.internal.Pushover] - Application API token not specified.
As soon as I add the api and userkey token in the pushover call, all works fine.
There is no typo error in both token since they were copied from the pushover section in the openhab.cfg file.
Any thoughts ?
does work!
There are no typos in the tokens and I’m pretty sure all devices are registered properly (Android phone with latest Pushover app) otherwise the 2nd option would not have worked either!
