Pushover notifications used to work properly for a long time but after upgrading to OH2.1 it stopped working. I changed nothing in my system.
Pushover itself works fine. When i send a test message from the Pushover website i get the notification instantly on my phone.
I checked the pushover.cfg file and all is fine (nothing changed).
I also checked the OH logs and also there all is fine.
For some reason OH is not using the pushover API and sending the notifications to pushover service.
Does anyone have any idea what could be the reason? I uninstalled rebooted and installed thew pushover action in OH but it didnt help. Cant figure out what else could be causing this.
Unfortunately not
Can only tell that pushover still works fine with 2.2 snapshot … and used to work with 2.1 snapshot also.
Did you double/triple check your credentials?
Thanks for your quick response. Yep checked that too. it didnt exceed the limit. its driving me nuts. doesnt make any sense. everything is there as it used to be.
forgot to mention, yes i also checked the credentials. everything is correct. i hadnt touched any of these anyway. it just stopped working. i mean pushover itself works. but OH service is just not working.
