I’ve built a scheduler using some of the tutorials here and i have some problem.
Items
Switch HVAC_VALVE01_SCHED05_ONOFF "Scheduler ONOFF"
Number HVAC_VALVE01_SCHED05_URA "Hour"
Number HVAC_VALVE01_SCHED05_MINUTA "Minute"
Switch HVAC_VALVE01_SCHED05_PO "Monday"
Switch HVAC_VALVE01_SCHED05_TO "Tuesday"
Switch HVAC_VALVE01_SCHED05_SR "..."
Switch HVAC_VALVE01_SCHED05_CE "..."
Switch HVAC_VALVE01_SCHED05_PE "...."
Switch HVAC_VALVE01_SCHED05_SO "..."
Switch HVAC_VALVE01_SCHED05_NE "..."
Switch HVAC_VALVE01_SCHED05_VALVE_SET "Set item t this value after scheduler runs"
Rule
rule "Urnik Openhab v2.2"
Time cron "0 0/1 * * * ?" // every minute
var Dan = ""
// Get day of a week and write it to variable that has item name
switch now.getDayOfWeek{
case 1: Dan = "HVAC_VALVE01_SCHED01_PO"
case 2: Dan = "HVAC_VALVE01_SCHED01_TO"
case 3: Dan = "HVAC_VALVE01_SCHED01_SR"
case 4: Dan = "HVAC_VALVE01_SCHED01_CE"
case 5: Dan = "HVAC_VALVE01_SCHED01_PE"
case 6: Dan = "HVAC_VALVE01_SCHED01_SO"
case 7: Dan = "HVAC_VALVE01_SCHED01_NE"
logInfo("DEBUG", "DEBUG 1")
// Check if scheduler is enabled
if(HVAC_VALVE01_SCHED01_ONOFF.state == ON) {
logInfo("DEBUG", "DEBUG 2")
logInfo("DEBUG", "Urnik je vklopljen")
// Check if this day is enabled
if(Dan.state == ON) {
logInfo("DEBUG", "Danasnji dan je vklopljen")
// Check time
if(HVAC_VALVE01_SCHED01_MINUTA.state == now.getMinuteOfHour && HVAC_VALVE01_SCHED01_URA.state == now.getHourOfDay) {
// Run scheduler
HVAC_VALVE_01_STS.sendCommand(HVAC_VALVE01_SCHED01_VALVE_SET.state as StringType)
} else {
logInfo("DEBUG", "Urnik NI bil izveden")
My problem is that i cannot use Dan.state so i can run code if day matches. If i set it to fixed item name it works.
I also want to write HVAC_VALVE01_SCHED01_VALVE_SET item value to item HVAC_VALVE_01_STS but it does not work like this.
Cand anyone help me with that?
